It is currently Fri Oct 20, 2017 3:15 am
 Post subject: what cams do I have?
PostPosted: Sat Aug 17, 2013 7:18 am
Hello everyone, I have a newbie question re: identifying aftermarket cams.....
Gti I recently purchased had "aftermarket" cams installed which made idle and stop-n-go traffic a little rough as my everyday ride. Anyway I removed these today and replaced with original cams.. Test drive proved much more comfortable, great!
Now the downside is that I have noticed a major change in power and delivery of power.. I expected a change maybe not this much :roll: I'm just curious now to know exactly what cams these are :?:
IN LAME/NEWBIE TERMS What measurements do I need?
 Post subject: Re: what cams do I have?
PostPosted: Sat Aug 17, 2013 7:59 am
Who did you buy the car from?
Measure the overall height of the lobe, then the smaller diameter (base circle). Subtract the base circle from the height, and that's your lift.
Let us know what it is and we may be able to figure out what profile it is. I sell a lot of DOHC sets in Australia, so they may be one of my grinds.
PostPosted: Mon Aug 19, 2013 1:24 am
height of the lobe is 40mm and base circle 31mm.
these are the cams in question. is it a regrind?
PostPosted: Mon Aug 19, 2013 12:53 pm
The numbers would indicate that it's a reground cam, with lift in the 9mm range. It could be a set of my 210/340 or 218/350 cams.
PostPosted: Sat Aug 23, 2014 2:32 pm
whats the difference between those two profiles?
PostPosted: Mon Sep 01, 2014 1:00 am
Those have to be regrind cams because they are hollow. Any aftermarket cams would be solid cams
1993 Suzuki Swift GT DOHC / 5-speed
1996 GEO Metro 1.0 3 cyl. / 5-speed
Other cars & motorcycle:
  • 2001 S10 Xtreme
  • 1996 Impala SS
  • 1994 Camaro Z/28
  • 1988 Honda NX650
  • 1980 Honda PA50
Shimaze's cars
PostPosted: Tue Sep 02, 2014 9:38 am
cat cams sells them hollow :lol: :lol:
Users browsing this forum: No registered users and 8 guests
