It is currently Fri Jan 19, 2018 5:25 pm
 Post subject: G10 valve springs
PostPosted: Wed May 07, 2014 3:01 pm
Can anyone say whether the G10 valve springs will work in the G13 (GTI) head ??
If not, what options are there for upgrading the GTI valve springs. Is there an inner spring that will work on the GTI head ??
 Post subject: Re: G10 valve springs
PostPosted: Thu Feb 26, 2015 7:07 pm
I have the same question... and furthermore what other valve spring will work with a GTi DOHC head? I have a set of cams for mine and the spec'd out at 322 lift/220 Dur @.050 lift. And siince the head is a bit old and I got it from a racer I want to replace the valve springs befor I turbo it.
PostPosted: Thu Mar 12, 2015 2:48 pm
I was told no by the folks at Ferrea. they said they don't work. I did find some from Elgin that will though. need new spring guides and retainers for the dual spring.
