It is currently Wed Jan 17, 2018 5:28 pm
 Post subject: fuel problem
PostPosted: Tue Sep 02, 2014 6:00 am
hello!
in saturday i drove to work with no problems, but after work engine didn't want to start.. starter worked ok but engine didnt even try to start..
few hours later i came back to car with tools and everything but car started with no problems.. then it ran whole weekend with no problems, for about 150km..
yesterday i tried to start it but in 1sec after start it died.. later i tried to block return fuel line and it started.. it was late so i went to bed and today i tried again and with open return line it's like it was in saturday after work, and with blocked return line it want to start but cant..
so, what could be problem? fuel pump, fuel filter or fuel pressure regulator? anything else maybe?
thanks
 Post subject: Re: fuel problem
PostPosted: Sun Sep 07, 2014 9:44 am
Sounds like a fuel pump to me! To diagnose listen when you first turn the key on, u should hear the pump run for about 3 seconds and then shut off.
To troubleshoot next time it happens take a soft face mallet and give the fuel tank a wack or two near where the pump is in the tank! If it is a intermittent pump then usually it will kick in after a wack or two! Just my personal experience! Good luck!
PostPosted: Sun Sep 07, 2014 11:16 am
got new pump and filter, but even before i changed them i replaced ecu (needed to change it anyway to put sandro's chip in) and it look like engine work normal now..
it might be bad contact or something like that in ecu or somewhere in ecu harness..
