It is currently Thu Oct 19, 2017 7:44 am
PostPosted: Sat Oct 18, 2014 7:00 pm
Just finished putting my 93 Swift GT back on the road after it had been in pieces for a number of years, the dis-assembly done by a previous owner...Did my best to reconnect all the vacuum lines....engine block mostly just a bare block..ECU and even injectors disconnected. Bought a manual and reassembled it. It ran great when i finally got the powered. Lots of power...its a blast to drive.
Now for my problem....when the car is running for about an hour...earlier in warm weather...later in cooler weather...it will suddenly lose power...gradually...until it barely stays running. Severe backfiring can be heard, especially as I attempt to accelerate....making me think this is an electrical issue. It never stalls...idles rough....but loses almost all power. If I stop and let it cool for a period, it will run well, then quickly resort to the unfortunate set of circumstances I just described. Sometimes the symptoms will go away for brief periods of time, only to return quickly. If the car is allowed to cool for an extended time, it runs as normal...
So, what are your thoughts?...awesome car otherwise---Mike
PostPosted: Sat Oct 18, 2014 9:56 pm
Check your codes and se what it's showing.
Ken............
PostPosted: Sun Oct 19, 2014 8:45 am
Hi,
Yes, as posted above, please get some codes from the ecu. Code diagnostics can be found here: http://www.redlinegti.com/forum/vth.20895.error.htm
I'm thinking Engine Coolant Temperature Sensor (ECTS) issue.
Please let us know how you go! It helps others searching through the forum. :)
Cheers,
Drew
スズキ カルタス GT-i
PostPosted: Sun Oct 19, 2014 9:03 am
there are 3 engine coolant temp sensors.. one goes to dash so you can see engine temp, second goes to ecu, so ecu know how hot engine is and third one is there to start radiator fan..
the one that goes to ecu.. blue one.. if engine temp goes too high or if you disconnect this sensor.. ecu won't let engine to rev up.. so if engine goes ok once it cool down, try replacing this sensor..
PostPosted: Sun Oct 19, 2014 10:53 am
good call on the bad clt. :wink:
PostPosted: Sun Oct 19, 2014 11:49 am
If no codes, issue is probably fuel related.
PostPosted: Thu Nov 06, 2014 1:06 pm
Ignition coil or igniter
It should be very hot when you lose power. After cooling it works again.
G13B 1.3L 16v 115hp
