It is currently Thu Oct 19, 2017 3:04 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Feb 18, 2015 11:01 am
Bump
___________________
89 Swift gti
PostPosted: Thu Mar 19, 2015 9:01 pm
A price has been determined for the pistons. They will cost $300 CAD. There is a choice of compression ratios from 11:1 to 13:1 approximately, dependent on the specifications of your cams and material taken off your head.
I can take orders for production now, and am excited to offer a great naturally aspirated piston solution at a reasonable price.
Thank you!
Levon
___________________
89 Swift gti
PostPosted: Wed Mar 25, 2015 12:34 am
anyone have those pistons in car & running already?
PostPosted: Wed Mar 25, 2015 12:38 am
not yet, the machinist is just finishing them up.
Listen to thine engine and mind thine tach, lest thine whirlybits seek communion with the sun.
1989 Suzuki Swift GTi, A work in progress as always.
PostPosted: Wed Mar 25, 2015 1:47 am
ok, so once you got em please take few pics :)
PostPosted: Sun Apr 26, 2015 10:15 am
interested in this, would I be able to order some around may or june?
PostPosted: Sun Apr 26, 2015 12:40 pm
Yes you can, orders can be taken whenever
___________________
89 Swift gti
PostPosted: Sun May 10, 2015 7:18 pm
Here are pictures of the finished product.
The piston with the higher dome is the modified piston vs the 1.2mm dome cultus piston.
Also this piston is 32 grams lighter than the cultus piston.
This will be a lot of fun!
Price: 300CAD plus shipping
___________________
89 Swift gti
PostPosted: Sun May 10, 2015 7:36 pm
Those are really nice! 8)
What is the compression ratio of that one with stock headgasket and unshaved head?
Also is there a max lift in cams that can be used with them?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Mon May 11, 2015 8:13 pm
Make love, not moderators
Wow they look great!
Do they come with rings?
And what combinations are you going to offer them in?
Size & compression ratio
This is very tempting..
PostPosted: Wed May 13, 2015 5:10 pm
Yes rings, pins and buttons are included, completely ready to install on g13b rods
The dome height can be modified to make the compression you want
Larger bore piston can be done as well.
edit- Larger bore sizes will cost more as the raw material cost more and there may be more machining.
___________________
89 Swift gti
PostPosted: Wed Jun 10, 2015 5:50 pm
Here are pictures of the pistons on rods.
___________________
89 Swift gti
PostPosted: Tue Jun 16, 2015 8:10 am
Very nice set of pistons.
I plan on rebuilding my 94 GT in a couple of months because my current engine have more than 240000 miles on it and it's making some piston slap noise and other engine noises. So, waiting for the winter to start the rebuild.
I'm not planning on going the Turbo route, so I think these pistons will be perfect for my first engine rebuild. I do have a couple of questions though!
1. To what exact size will I need to bore the cylinders for these to fit?
2. I know they're plug and play but will the 12:1 compression ratio ones fit on a stock engine without any other mods to the engine and/or ECU?
3. Price for a set shipped to G1G 3J1 (Quebec, Canada)?
4. Best cams to go with them in a street application?
Did someone tried them in a street application?
'94 Swift GT, Summer Beater.
'05 RAM 1500 5.7HEMI, Daily.
'01 Dodge Caravan, RIP.
'99 Mazda Protegé, RIP.
'92 Swift GT, SOLD.
'92 Swift GLX 4dr Sedan: SOLD.
'93 Metro, SOLD.
'86 Forsa GL, RIP.
PostPosted: Tue Jun 16, 2015 4:53 pm
You can run them with any cam you want, ask mike at 3tech which one suits your needs. I personally am running 222/365 which is the most aggressive he offers (I'm pretty sure)
These are 75mm pistons, it is best to wait until you get the pistons and take them to the machinist who is doing the work to measure them precisely.
You would probably want to chip your ecu to get the best out of the pistons.
Price is 300 CAD plus around $30 to ship
We can machine them to a lower compression ratio if you are just looking to freshen up your factory stock gt.
___________________
89 Swift gti
PostPosted: Tue Jun 16, 2015 6:34 pm
Are these solid dome?
Cars and Harleys
PostPosted: Thu Jun 18, 2015 6:20 pm
yes they are solid dome
___________________
89 Swift gti
PostPosted: Sat Jun 20, 2015 8:10 am
Are these still for sale in september/november, i have a 24 hour race ahead first, so need everyone penny for that first
PostPosted: Sat Jun 20, 2015 11:48 am
Yes they will be
___________________
89 Swift gti
PostPosted: Mon Jun 22, 2015 11:25 am
how long can these teflon buttons can last in a normal operation (daily driven)
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Mon Jun 22, 2015 9:01 pm
forever
___________________
89 Swift gti
PostPosted: Wed Jul 29, 2015 6:50 pm
Bump
___________________
89 Swift gti
PostPosted: Wed Jul 29, 2015 8:07 pm
could I shoe-horn these into a 1.0? or too much work? :huh: :blackeye:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Fri Aug 28, 2015 8:57 pm
I am taking customs orders now if interested, 75mm ranging from 10:1 to 14:1
___________________
89 Swift gti
PostPosted: Sun Aug 30, 2015 8:18 pm
Beachedbru, how much time does it take to ship to US since sending the money?
PostPosted: Sun Oct 18, 2015 3:45 am
I like your pistons, and i want to order 1 sett.
75 mm P29 G13B 12,0 : 1
Anders Öhman
Sweden
