It is currently Fri Oct 20, 2017 1:32 am
 Post subject: Fuel pump sounds quiet
PostPosted: Thu Mar 12, 2015 10:10 pm
Hi,
I tried to start my GT after a long period sitting, and the fuel pump was barely audible during ignition on priming.
I also tested the wiring to the pump from the connector to the back seat and have over 12 Volts and there is about 4 ohms resistance. (I am not sure if I am measuring something useful, but it seems to indicate there is not an open circuit)
The fuel guage shows near Empty. I suspect the fuel sock may be getting a bit clogged, I wonder if I should put in a few gallons of fuel in to see if I can get it started? Thoughts? Or should I just drop the tank and service the pump/sock?
(I am not sure if this is post is in the right section. If not, would a MOD please move this to Problems/Fixes?)
cron
