It is currently Tue Oct 17, 2017 6:19 pm
PostPosted: Mon Apr 06, 2015 9:58 am
For the engine to be set to the factory recommended degrees of timing you have to pull the distributor adjustment bolts out to get enough play of twisting the distributor.
Here is a list of what has been checked.
The crank pully TDC mark is actually not correct, its off by an inch or so (did it twist on the harmonic balancer?) But either way, pulled 1st spark plug and put in screw driver and found actual TDC and put new mark on Crank pully
Timing is correct, nothing is off by a tooth or anything strange
The key way on the crank and cog are in perfect condition
Distributor keys into cam offset only one way so that cant be off
New cap/rotor (is it possible a SOHC cap could have been given to me and it fits and is twisted slightly more than a GT?)
Good compression (200ish on all) and fresh head job so no leakdown
Its got me and all my friends confused and we are just scratching our heads now, maybe somebody put on a different distributor?
PostPosted: Mon Apr 06, 2015 10:32 am
what is the recommended ignition timming @ how many rpms?
first remove crank pulley and check timming with all timming belts pulley, allign crank accurately and check timmings marks on camshaft sprockets and post a picture
you can remove the bolt of the intake camgear to see if it correctly instaled with dowel pin on the camshaft
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Mon Apr 06, 2015 5:24 pm
Make love, not moderators
I'd like to know what is the problem with your car. You talked about a bunch of stuff that you did but you never told us what your car is doing or not doing.
Oh and sticking a screw driver in the spark plug hole to find tdc is NOT HOW THESE ENGINES ARE TIMED.
PostPosted: Mon Apr 06, 2015 7:18 pm
Hmm Haven't given that a look yet, I keep the car at the track so I cant post that picture now, but Ill get it here in a day or two
PostPosted: Mon Apr 06, 2015 7:21 pm
First line, you have to remove bolts holding in distributor to get it spin enough to time correctly
Got a better way to find TDC on an engine with the head installed and pulley with a screwed up mark?
PostPosted: Mon Apr 06, 2015 7:59 pm
Yeah, remove the pulley for the serpentine belt, line the dot on the front of the timing gear with the dot on the oil pump. problem solved.
PostPosted: Mon Apr 06, 2015 8:17 pm
Exactly. You line up all the timing marks like your supposed to and then use a timing light to adjust the distributor. And THEN you can use the little notch on the serpentine belt pulley with the front of the timing cover to set timing to 5degrees.
The distributor should only rotate maybe 30 degrees for adjusting purposes.. If you are that far out then your timing marks on the crank pulley and cam pulleys are way off.
PostPosted: Tue Apr 07, 2015 8:21 am
Touche haha Guess we just didn't want to take the front half of the motor off when the latter was so simple.
I need to get the car back here and dig back into this timing
PostPosted: Tue Apr 07, 2015 8:23 am
Yea its way more than 30 degrees, its gotta be something like the pin in the cams or something. I need to get a new crank pulley also to rule that out of the equation. Sounds like its time for an aluminum one haha
PostPosted: Tue Feb 09, 2016 2:38 pm
BIGOLBUMP
Still have the same problem and it is driving me insane at this point.
(Sparknotes)
All pulleys are lines up correct and its not off by a tooth.
Keyway is fine
compression great
Crank pully has "new" tdc mark (while inside bottom timing gear lined up correctly new mark was made on crank pully exterior)
And this is what it takes to get the engine timed correctly
Wrong distributor? Possibly a single cam distributor cap? Are the 3 cyl distributor screw in point diff/maybe I have one on my motor?
Im completely out of ideas at this point
PostPosted: Tue Feb 09, 2016 7:33 pm
Do your cam pulleys have two different dowel pin spots? Some Suzuki pulleys have two different dowel pin spots depending on whether they are on the intake or exhaust cam. Perhaps you have a pulley on the wrong dowel notch. May have to pull the cam bolts to confirm this, don't think you will be able to tell with the bolts and washers covering the centre of the pulleys when they are installed
PostPosted: Tue Feb 09, 2016 7:36 pm
Or is the distributor housing simply flipped around wrong, with the cap and rotor all aligned properly? Wondering what would happen if you pulled it out and spun only the housing 180 degrees(rotor position won't change), I think you will have to reroute your plug wires in order to flip cap 180 degrees as well
PostPosted: Tue Feb 09, 2016 7:39 pm
sorry for being a asshole but need to say :P
why no pictures of good timming mark and all?
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Tue Feb 09, 2016 7:54 pm
The flat spot and casting line in the pic would be indicators of housing alignment, I just don't have a gti motor in front of me to check whether those marks are normally at the top or are underneath on a proper gt aligned distributor. Anyone looking at a gti engine right now??
Superstrange wrote:
New cap/rotor
Wires off by one post
PostPosted: Tue Feb 09, 2016 7:57 pm
Keep it simple! I never thought of that
PostPosted: Tue Feb 09, 2016 8:00 pm
Yep, and they are on the right ones, have the pic on computer just forgot to upload those two
I thought about that, but didn't try it, distributor wires sticking out the top wasn't right, i might try that tomorrow just because why not.
The rotor can only go on one way so thats right, and dizzy can only index into cam one way
Just forgot, ill post them now
PostPosted: Tue Feb 09, 2016 8:02 pm
suprf1y wrote:
Superstrange wrote:
New cap/rotor
haha....uhhh I hope not but definitely worth checking in the morning haha
PostPosted: Tue Feb 09, 2016 8:06 pm
Here is intake cam, lined up, and the dowel in on the bottom on the "I" hole (not visable but not in the E hole that is visible)
here is the exhaust, lined up and dowel on the bottom in the "E" hole (not visable but not in the I hole that is visible)
Thanks for all the help so far, i will try those couple little things tomorrow
PostPosted: Wed Feb 10, 2016 11:52 am
Wires on are correct on the cap
SOHC and DOHC caps are different and I have the DOHC cap so thats right
Looked at pics of people engines and the wires do face the bottom of the distributor.
:dunno:
PostPosted: Wed Feb 10, 2016 2:45 pm
update, thought maybe it was an idle issue, held the throttle at like 2000-2500 somewhere around there and moved the timing on distributor back to where it should be and clug clug dead. so not an idle issue
PostPosted: Wed Feb 17, 2016 7:11 pm
Welp....sometimes if you have ruled out everything but one thing....its that one thing. My distributor was fubar
My known working second hand distributor IN BOTH PICS THE ROTOR IS FACING THE SAME WAY
(note position of the reluctor ring to the pickup....)
And this is the bad one (note position of the reluctor ring to the pickup this time)
Looks like the reluctor has spun on the shaft, Makes perfect sense...why it happened,....who knows, i bought it with a bunch of issues
What a total pain in the ass this whole adventure has been hahaha
Thanks for all the help guys, what a weird thing to be wrong.
PostPosted: Thu Feb 18, 2016 6:30 am
Just a thought, have these distributors have some kind of mechanical advance or electric advance mechanism built in to them, if so could it be stuck in full advance?
Current car's, 2007 Suzuki SX4, 1993 Holden Barina / Suzuki Swift
Previous Car's, 2X Sigma's ( 85 and 87), 2000 Mirage, a 1987 Isuzu Bighorn (Holden Jackarooo), 2005 Lancer and a 2002 (MY03) Nimbus
Suzuki, The New Way Of Life
