It is currently Sat Oct 21, 2017 9:12 am
 Post subject: Thermostat Base Needed
PostPosted: Thu Apr 30, 2015 1:01 pm
image_id: 24124
I have what I believe is a MK2 1.3L DOHC GTi motor, although not entirely sure, it was a take out that I bought from a friend to use in a Samurai...
Anyway, it's mostly complete except for one key part, the thermostat base that bolts to the rear of the head is missing...
It's item #2 on the picture above. I have a right angle cap, but no base.
Does anyone have one they'd be willing to sell, or know where I could source one?
Any help would be appreciated. Thanks...
PostPosted: Mon May 04, 2015 12:57 pm
I'm also looking for a G13B STi throttle body if anyone has upgraded their stock unit, I'd be interested in buying your original.
Thanks,
PostPosted: Mon May 04, 2015 3:58 pm
Hi there is an original thermostat housing with 90 degree outlet
it is 17561-63B01 part number suzuki
It is from SF413
I use it in my gti samurai
PostPosted: Tue May 05, 2015 11:56 am
Thanks very much for the reply. Actually I have that very same cap, but I need the base it bolts to. On the G13K (DOHC), there is a base that bolts to the rear of the head that this cap mounts to. That is what I'm looking for and have had no luck in finding one.
PostPosted: Tue May 05, 2015 2:30 pm
SOHC 16V G13B has the same base , I think. Find a Metro or a Swift with that engine in the junkyard and you found your part
PostPosted: Wed May 06, 2015 2:17 pm
OK, thanks very much DTM GTi, I will try that!
PostPosted: Thu May 28, 2015 6:56 pm
Nope, from what i've found the 16v sohc has a two bolt base, the gti has a 3 bolt base.
PostPosted: Wed Jun 10, 2015 6:07 pm
I have this part I send to you a message
Users browsing this forum: Bing [Bot] and 5 guests
