It is currently Wed Oct 18, 2017 5:34 am
 Post subject: Same head?
PostPosted: Wed May 06, 2015 9:00 am
Is it the same head on the mk1 swift gti and the mk2?
I notised that the mk1 head have a hollow camshaft. The mk2 have a solid one. Both came from a g13b block.
 Post subject: Re: Same head?
PostPosted: Wed May 06, 2015 9:04 am
mk1 mk2 hollow camshaft mk3 solid
mk1 dohc have a slightly different casting, some difference on intake flange, (coolant tubes) , intake and exaust ports are different on mk1
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Wed May 06, 2015 4:19 pm
Ok. Are all the G13b all the same? Both from sohc and dohc?
PostPosted: Thu May 07, 2015 6:22 pm
The blocks for the MK1 have different engine mount locations (because the actual mount system is different). Sump is slightly bigger along with the oil pickup and the whole engine tilts forward more than the later engines. The mount point on the block for the short shaft from the gearbox is different.
Blocks for MK2/3/4 are the same BUT things like pistons are different for the various head / cam / valve / compression combinations.
MK2/3 gearboxes are the same but MK1 gearbox and mounts are completly different. AWD is different again.
PostPosted: Thu May 07, 2015 11:39 pm
sohc 16v head is different from all dohc engines..
block is more or less same as mk2/3 dohc i think..
PostPosted: Thu May 28, 2015 4:59 pm
Thanks
