It is currently Fri Oct 20, 2017 4:07 pm
 Post subject: Need chip
PostPosted: Sat Oct 24, 2015 9:10 am
Hey guys, want to give some more power to my swift. Currently i have some minor mods like
48.8mm pipe, 4-1 headers, and an intake
From what i have seen the best chip to use on a dialy car its the toms. Anyone suggest another one?
I don't want to have the check engine light on.
I also have a small problem with idle, sometimes it idles high, other times low, can a chip help me even a tiny bit to overcome that?
What true hp gains will the chip give? Are they noticeable?
Thanks in advance
 Post subject: Re: Need chip
PostPosted: Sat Oct 24, 2015 9:21 am
Sandros chip.
His GT (swifty92) ran a high 14 with that chip and bolt ons.
I also use it and it's the best.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sat Oct 24, 2015 9:58 am
But i heard that the idle is way too rich? That wouldnt help the problem i currently have with idle :?
PostPosted: Sat Oct 24, 2015 10:44 am
you need to sort out all your idle issues before you start modifying your car. :wink:
PostPosted: Sat Oct 24, 2015 11:55 am
+1.
2003-EVO7 GT-A
PostPosted: Sat Oct 24, 2015 11:56 am
I have a wideband. Idle is fine.
2003-EVO7 GT-A
PostPosted: Sat Oct 24, 2015 12:10 pm
I sell custom chips, check my signature.
Though I sell chips, I recommend that anyone that is serious about making power tune their ECU with an emulator http://www.moates.net/ostrich-20-the-new-breed-p-169.html. That way you have full control over your fuel and timing maps, but you also need to install a wideband AFR and learn some software.
Chips are still a good option for those that need improved engine management and don't want to spend more than $100, though, and I'd argue that there's a lot of bang for your buck. The gains are not large--in fact you might need quite a few dyno runs to verify that you've gained anything, as they will likely be in the 2-5 hp range--but they are real. HP does not materialize out of thin air, however. Chips develop more power because they raise the rev limiter (reason enough to chip IMO) and use a more aggressive timing map. That more aggressive timing map means you need to run premium gas, but that's where the extra energy comes from.
The downside of a chip is that no chip is ever quite perfect for any car it wasn't dyno tuned for. Sandro's chip does work well, and usually better than Toms, even with milder mods, but it works best in a Cultus-clone engine with 210/340 cams because that's what he had in his car when he had it tuned. A great deal of work and thought went into making the Toms chip and it was designed, in theory to work well in many setups, but no one I know has gotten good dyno results with it (poorer than stock, actually). I have a library of tunes including both Toms, Sandros and the one I use on my own car that is probably a decent match for your mods (I run a Cultus intake and extractor with standard pistons). I think my chips are the "best" because I combine the maps you choose with the OEM code for your specific ECU, so I can gaurantee you will not have a CEL and your OBD I codes will function normally. Further I am the only vendor that will leave closed loop operation intact so that your ECU can make adjustments to keep you AFR correct at cruise and idle if you choose to do so (which I recommend).
Fix your idle issues first, then send me a PM :D
PostPosted: Sat Oct 24, 2015 1:05 pm
The problem might be in the distributor, lets see
PostPosted: Sat Oct 24, 2015 1:06 pm
Thanks for that large explanation! You got a pm
PostPosted: Sun Oct 25, 2015 4:01 pm
i used sandros chip in my car with 210/340 cams.. once i went back to stock cams this chip was way too rich..
atm i have some "GrA chip" from guy from australia (redlinegti forum) and it work best with stock cams and compression.. i can use 95ron gas and comsumption is about same as stock chip.. i don't think i gained much HP.. but power curve is for sure much better.. car gets power at lower rpm and it goes a little over stock revs before it lose power (it's useless to go over 7k rpm on stock cams anyway, except maybe a little if you need to push from corner to corner.. or maybe in 1st gear to get better revs once you shift in 2nd)
so it's up to you.. do you want max power on paper or do you want car that will have best power range while driving around?
unfortunately i dont have any dyno graphs or anything to prove my words..
PostPosted: Mon Oct 26, 2015 1:21 am
Having more power a low and mid range would be awesome actually
