It is currently Tue Oct 17, 2017 8:28 am
 Post subject: Fuel Injector Connectors
PostPosted: Sat Jan 16, 2016 6:32 pm
Guys I found a supplier for the GT fuel injector wiring ends.
They come with better release clips then the stock connectors
and 6 inches of lead wire.
Fainya
PostPosted: Sun Jan 17, 2016 3:55 pm
Awesome.
What's the plan?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sun Jan 17, 2016 4:28 pm
Make love, not moderators
So who's the supplier?
PostPosted: Sun Jan 17, 2016 8:32 pm
The plan is to use the original injectors and fuel rail on my 1990 DOHC engine with 98 SOHC PCM, engine controls,
and wiring harness in my 97 Geo Metro. The GT injectors use a different wiring end then the 98 injectors,
I will be adding a supercharger to the engine. The reason for wanting the original injectors back on the DOHC
is the GT injectors flow more fuel then the 98 injectors. I will need the additional fuel with the supercharger.
The 98 engine controls will give be sequential injection and with ODB2 I can see what is happening,
the 90 GT engine controls only did bank injection, and with ODB1 there is no way to see what is happening without
adding a $300+ piggy back control to the ECM. Also no distributor is needed with the 98 electronics.
As far as who the supplier is, it will be me. $8.00 per end with wiring plus shipping.
The DOHC engine was installed and run for about 10,000 miles. I have since rebuild the SOHC 16 valve engine and
have swapped it back into the car. The DOHC is on the engine stand in the shop. I do not want to fabricate brackets,
hoses,harnesses,and stuff for the supercharger while the DOHC was in the car.
DOHC engine being installed and removing the 98 SOHC engine.
Fainya
PostPosted: Sun Jan 17, 2016 9:10 pm
While you're at it, it would have been smart to use an alternative injector. The DOHC injectors are garbage, and I'm not sure the later computer will even be able to control them well enough to fuel the motor properly.
PostPosted: Mon Jan 18, 2016 6:55 am
The only way to find out will be to use them. If they don't do what I expect there are other injectors out there.
The biggest changes will come with reprogramming the PCM.
Fainya
PostPosted: Mon Jan 18, 2016 4:47 pm
Your going to want to make sure the resistance for 90 injectors is the same for the 98..
GT injectors are 2 ohm units.. If the 98 uses higher impedance ones, your out of luck, you will fry the ECM..
And telling everyone you found a supplier for pigtails, and then not sharing it so you can be the one everyone has to deal with makes you look like a douche.
PostPosted: Tue Jan 19, 2016 7:05 am
The source for the pigtail ends is the GM assembly plant in Grand Prairie, Texas. One of my friends
works for the parts aquisition department. It is through him that I was able to obtain some overstock
pigtail ends. It is not likely I can get more then the 50 ends that I had to buy.
So if you find a source, I am sure the team members would be interested.
This is the best I can do for now on a part that is almost impossible to find.
Fainya
Users browsing this forum: Majestic-12 [Bot] and 3 guests
