It is currently Tue Oct 17, 2017 10:07 pm
 Post subject: G13B Pistons
PostPosted: Thu Jan 28, 2016 9:30 am
I'm doing a engine rebuild on a G13B atm, and it looks like I'm going to have to get oversize pistons the bores are out of round badly. Is there a good source for as close to stock as possible 75mm pistons? I can't seem to find them anywhere, this build is just a stock build, nothing fancy on this one. Is my only option to order these viewtopic.php?f=16&t=61095 . I was hoping I could find regular non custom ones more in the $200 range. Thoughts?
89 Suzuki Swift GTI
15" Lancer OZ Racing Rims
Custom Trailing Arms by Dethbrd
Boxed Rear Control Arms
Super Pro Poly Bushings
Genie Header
Nissan Intake Manifold
2 1/4" Exhaust
Turbine Tech Underbody Brace
Honda CRX Front Brake Calipers
 Post subject: Re: G13B Pistons
PostPosted: Thu Jan 28, 2016 2:33 pm
I think there was someone who bought oversized GT pistons from NAPA.
viewtopic.php?f=4&t=59918
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Jan 28, 2016 4:23 pm
Nice! I'll have to see if I can still get those. That's exactly the kind of thing I was looking for, not looking for fancy high compression or anything just a tight standard engine when I'm done.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Thu Jan 28, 2016 4:30 pm
Looks like NAPA still shows them online, I'll report back if I'm able to get a set.
http://www.napaonline.com/Catalog/Result.aspx/Suzuki-Swift-1994/_/Ntt-piston/Ntk-Keyword/Nty-1/N-599001%20101994%2050069%202069006%204069001%205999999%2025010/Ne-25000
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Thu Jan 28, 2016 6:57 pm
macuserman wrote:
Awesome!
But what's the price for a set? Can't see that anywhere on the site.
2003-EVO7 GT-A
PostPosted: Fri Jan 29, 2016 8:05 am
Online it shows 104 for the piston set and 58 for the rings. Price will probably be a little different with tax and whatnot since it won't let me order them online I have to go to the store.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Feb 08, 2016 9:47 am
So that was a bust, Napa says no can do anymore. So back to the drawing board.... Anybody else have ideas? Just looking for standard compression oversized pistons.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Feb 08, 2016 10:56 am
I can do up a set of the D16 pistons at stock compression ratio, but it's a little more than $200
PostPosted: Mon Feb 08, 2016 11:27 am
What kind of price are we talking about?
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Feb 08, 2016 11:35 am
PostPosted: Thu Mar 10, 2016 2:37 pm
Does anyone know if these pistons will work? It says so in the compatibility at the bottom, but I'm not sure I trust it.
http://www.ebay.com/itm/Engine-Piston-Ring-ITM-RY6413-030-/111488485490?fits=Make%3ASuzuki%7CModel%3ASwift%7CSubmodel%3AGT&hash=item19f53b4872:g:gJ8AAOSwUuFWvafo&vxp=mtr
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Thu Mar 10, 2016 5:27 pm
I see 2 valve cut outs on top of the pistons. So it's for an 8 valve engine.
I'm not sure it could work in a gti engine.
I can't see the piston diameter or pin diameter in the discription.
Why don't you search for "g13bb pistons" on ebay?
The seller "carpartswiz" has pistons that can work in a gt engine for under $100. He also has oversize ones.
2003-EVO7 GT-A
