It is currently Sun Feb 18, 2018 6:51 pm
 Post subject: Is this normal?
PostPosted: Sat Jan 30, 2016 6:16 pm
When i put the key in the position where the car pushes fuel in order to start, the last one before crank, if i take sometime to crank, it will not start, when that happens i have to go again to on position, push fuel and then crank it and it starts. 10/15 seconds is enough for it not to start.
So if i start the car seconds after it stop pushing the fuel, it cranks normal, if more then 10 seconds it wont start.
Is this normal? Has anyone noticed this in your cars?
94 swift gti
 Post subject: Re: Is this normal?
PostPosted: Sun Jan 31, 2016 6:15 am
it only "push" fuel for about 3sec then in time pressure will go lower and at this point there is not enoug fuel to start the engine.. atleast i think it's that way..
mine do the same..
