It is currently Sun Feb 25, 2018 11:23 am
PostPosted: Thu Feb 18, 2016 9:15 pm
Can anyone confirm or deny? Also, can you tell me where to get one in the states? :D
(That was sarcasm, because I'm doubting I can get it)
PostPosted: Fri Feb 19, 2016 2:57 am
You can get them in Europe with drums in the back on a regular Swift but if you want the discs then its Japan
PostPosted: Fri Feb 19, 2016 3:07 am
I may need to find a way to get them shipped to the states, because that would be amazing for a rally build.
PostPosted: Fri Feb 19, 2016 3:19 am
That depends on your rally rules, most countries I know of will stick you in the same class as Evo's and Wrx's because you are now 4wd, you can't ever be competitive with proper 4wd rally cars no matter how much money you throw at it.
I know of a local swift 4wd rally car that had the rear part of the gearbox blanked off and the rear running gear removed to make it fwd, it was a class winning fwd car.
It's actually a massive job to convert a 2wd swift into 4wd, the rear floor pan is completely different, the steering rack is mounted much higher so the firewall is also different as well, tons of different parts.
PostPosted: Fri Feb 19, 2016 3:52 am
That's strange to me. I've been told that the stock gearbox is weak, (even though the G13 is a strong engine,) and wouldn't be a good build for rally..
Maybe I'm misinformed.
PostPosted: Fri Feb 19, 2016 3:55 am
The small framed fwd box is weak, very weak, however the 4wd gearbox is much bigger and twice as strong, it can be converted to fwd.
PostPosted: Fri Feb 19, 2016 4:23 am
Well, I know what I'm going to need to invest in!
PostPosted: Fri Feb 19, 2016 7:15 am
Mk1 fiend
Mk1 fiend
The G16B sedan AWD has the same gearbox, more likely available in Northern America.
The other option was that many of the G16B sedans also had a FWD box that is equivalent - the AWD box with the rear transfer blocked off.
Both these gearboxes are dual cable link for the gear change and have hydraulic clutches. So very different from the G13 boxes.
There are three kinds of people in the world, those that can count and those that can't :)
PostPosted: Fri Feb 19, 2016 7:39 pm
Buy the bits you need off this guy and use a local J18 box, Shamaze has a thread I think on it.
http://www.redlinegti.com/forum/viewtop ... =3&t=54383
