It is currently Thu Oct 19, 2017 9:04 pm
PostPosted: Fri Feb 19, 2016 3:08 am
Cold start, it idles at about 500, and is weak. Operating temperature it's at about 1400.
What could be the issue? :o
It's not a new issue, just something I feel I should have addressed awhile ago. Thank you.
PostPosted: Fri Feb 26, 2016 10:01 am
There is a possibility that neither of the idle control valve work/are hooked up/exist, and that the idle screw has been fiddled with to compensate. I would start be verifying you do or do not have a coolant controlled cold start valve on the firewall side of the intake by the throttle body, and then see if you have an electrically controlled idle air control valve on valve cover side of the intake towards the drivers side.
