It is currently Tue Oct 17, 2017 1:55 am
PostPosted: Sat Feb 27, 2016 8:04 pm
hey guys my idle air control valve is not hooked up and i always drove the car with the idle set at 1000rpms (i adjusted the screw on the throttle body to this position. however while i am driving the car will die when i throw it in neutral. i found out that the idle speed screw is tightening itself to close while i am driving and i keep having to take a screwdriver and turn it back out to get the car to idle right. how can i stop the screw from tightening itself back and keep it at its fixed position??
1989 Suzuki Swift GTI 2'' straight pipe from Cat back
1994 Suzuki Swift GT (My Brothers Car) Who is actually the original owner from 1994 when our father bought the car from the suzuki dealership! 80000 orig.miles currently
PostPosted: Tue Mar 01, 2016 9:39 am
You could try a dallop of gasket material on the screw head and let it sit overnight. If it doesn't work you just peel the material off and try something else...
1993 Swift GT
PostPosted: Tue Mar 01, 2016 11:25 pm
Yeah I put some rtv on it and it seems to have done the trick. Thank you
