It is currently Sat Jan 20, 2018 4:15 pm
PostPosted: Sat May 14, 2016 3:22 pm
Hi
I am about to put a new set of bearings in my engine as part of a refresh.
I am slightly confused around the markings on the bearings.
The first picture is the conrod and the code is 8J43B on both parts of the bearing.
The second and third pictures are one of the mains bearings with different codes on each side 9B52S & 9C03S
If anyone can give me some help it would be appreciated.
Thanks
Jon
PostPosted: Sat May 14, 2016 7:44 pm
Do your main bearings have the oil hole in each half ? If not that would be why there are different numbers.
Ken.............
PostPosted: Sun May 15, 2016 3:13 am
Hi
Mains i have found are different parts so i can see why they would be different.
Having looked around it doesn't look as simple as other brands where the bearings are just markes as standard or +.25 for example.
I believe you have to look at some numbers stamped on the block ?
