It is currently Sun Feb 25, 2018 9:14 am
 Post subject: '89 twincam issue
PostPosted: Thu May 19, 2016 8:00 am
so, I think I hurt it.
wound it up pretty high, awesome launch, but then the problem showed up
will not idle, very hard to start, will not rev freely until you feather it over 3000 rpm, then it revs freely, but has no power to move on its own.
so far I have checked the dizzy, plugs (they were loose :huh: ) no damage or deposits just sooty, timing marks line up, has compression (135, 145, 150,150)
no unusual noises
slipped crank cog, or broken cam? :huh: :huh:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
 Post subject: Re: '89 twincam issue
PostPosted: Thu May 19, 2016 6:47 pm
Make love, not moderators
Yeah I would definetely check the timing marks to make sure..
Also, just to be sure, check your fuel pressure, It sounds like it is starving for fuel.
PostPosted: Thu May 19, 2016 7:02 pm
new fuel pump last year, but you never know...... :roll:
3 tech 6*gear
gti brake swap
PostPosted: Thu May 19, 2016 7:07 pm
my moneys on slipped cank cog .. timing marks will be spot on because your belt did not slip Just be thankfull you didn't granade you Transaxle They wont take that kinda abuse for to long....jv&s
PostPosted: Thu May 19, 2016 7:44 pm
yeah, 8600 + rpm comes up pretty quick...... :shock: :twisted: :twisted: :twisted: :twisted: :twisted:
3 tech 6*gear
gti brake swap
PostPosted: Fri May 20, 2016 8:14 am
fuel pressure tested fine.
3 tech 6*gear
gti brake swap
