It is currently Tue Oct 17, 2017 3:21 pm
PostPosted: Fri Jul 01, 2016 1:25 pm
I have been looking at G13B DOHC connecting rods. I see a lot of them in the $300 range that are made in Hong Kong. Has anyone used these forged brands and are they good. They look well made and are sold on EBAY and Amazon. The link is one example.
I am going to be using them in a G10 engine modified for a small supercharger.
https://www.amazon.com/maXpeedingrods-E ... B00RYGIQ3G
Thanks for any help
1971 Honda N600 Transplant
w/ Suzuki G10 engine
and 5 speed trans
PostPosted: Fri Jul 01, 2016 1:44 pm
overkill.
Stock rods are fine
PostPosted: Sat Jul 02, 2016 10:46 am
I have those rods. Didn't install them yet. But they're indeed overkill.
I'm boosting 18psi on stock GTi rods and stock compression ratio and they're still holding. As long as it doesn't detonate, it'll be fine. I'm using water meth though.
I'm even thinking on boosting on some high compression pistons and stock rods.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sun Jul 03, 2016 9:21 am
I would be happy to use stock B13B rods if I could find them easily in the USA. If I do find a set I will most likely be close to the aftermarket price when shipping is included. The aftermarket rods are easy to get. I only need (3) and I really question if the G10 rods can deal with every condition. I am using an EMS-4 and tuning from scratch.
instant_shine who makes your aluminum flywheel and how much does it weigh? B13B OEM flywheels are also hard to find.
and 5 speed trans
Users browsing this forum: Bing [Bot] and 4 guests
