It is currently Sat Feb 24, 2018 2:19 am
PostPosted: Sat Sep 03, 2016 1:01 pm
Looking to anyone that knows what the difference is between the Gt and mk4/5 front strut brace? Anyone know if I could a Gt one to work on my 1999 swift chassis with a Gt engine? I really like the looks of the ultra racing one but don't wanna pull the trigger on buying one if I can't make it work. If it's just a matter of drilling different holes to make it fit then that's no biggie. Thanks in advance.
PostPosted: Mon Sep 05, 2016 12:19 pm
You could look for the chassis dimensions / measurements for both cars and then compare. I know the GT one is around. The mk4/5 should be also.
2003-EVO7 GT-A
PostPosted: Mon Sep 05, 2016 4:37 pm
Only one company makes a brace for the mk4/5 and its cheap and very flimsy looking. Was just curious if anyone has used a Gt one on the newer body style.
PostPosted: Thu Sep 08, 2016 2:00 am
Will be figuring it out here in the next couple of days as I will be making one for my 1996 Geo. I will be using as a template the ones that I bought from Murr at TurbineTech. Also, I will be making the lower brace and the rear tower brace. Another one is the floor brace behind the seats at the bolt hole for the shoulder harness.
clinty wrote:
pacapo wrote:
JVS wrote:
PostPosted: Thu Sep 08, 2016 2:53 pm
I'm almost 100% certain the only difference is the hole size at the front large control arm mounting point. I have both braces, I'll try to look at them and confirm that. Perhaps try a pm to turbine tech, Jess might be nice enough to clarify, he will know
PostPosted: Thu Sep 08, 2016 4:14 pm
Why don't you fab one up yourself. There's not much to it
PostPosted: Thu Sep 08, 2016 8:19 pm
My bad I thought he said strut brace not underbody brace. I'm going to be doing all of them for my 96.
PostPosted: Fri Sep 09, 2016 6:42 pm
Nope, you win! The thread is called "front strut brace fitment". I was rambling about the wrong thing. I'd almost bet the strut one is the same. That is an easy thing to measure, I'll try and check a mk2 compared to mk4
PostPosted: Fri Sep 09, 2016 8:05 pm
Actually, I wouldn't even bother with one. The underbody brace is the important one. the strut mount are so close to the firewall, they're not going anywhere
PostPosted: Fri Sep 09, 2016 10:27 pm
Even under racing conditions Mike? I have a lower turbine tech brace on the car already. Just thought the top should have some support too.
