http://www.teamswift.net/
sr20tb issue
http://www.teamswift.net/viewtopic.php?f=4&t=62255
Page 1 of 1
Author:  sgr16v [ Wed Jan 18, 2017 1:16 pm ]
Post subject:  sr20tb issue
when i swapped the 55mm sr20tb (was already running a cultus intake) in my samurai gti i'm having an idle issue.I have the tps adjusted as usual with a filler 0,65mm from tb adjusting screw(which i did not touched).Then When cold idles to 2000rpm which is ok.At hot operation idles on 900rpm which is good.But the problem is when i operate the hydraulic steering wheel in a static potition,rpm drops alot to 400-500rpm which often stalls the engine.Then i have to crank it again.
If i put back the stock tb and readjust the tps,i dont have this issue.It drops to 700-800rpm.So there is something to do with the tb.Beside this is running great and gives a great response and sound..
Should i raise a bit the idle from the adjusting screw and readjust the tps or look something else.
Author:  sgr16v [ Sat Jan 21, 2017 10:24 am ]
Post subject:  Re: sr20tb issue
Any suggestion on this?
Author:  suzukitom [ Sun Jan 22, 2017 2:35 pm ]
The factory approach is to use various sensors to allow the ECM (engine control module) know to increase idle air to compensate for increased engine loads whether it from switching A/C on, defogger or heater on, or power steering demands. Some components used in idle control are the IAC (intake air control valve) , a stepper motor on the throttle, etc. You may need to consult the FSM (factory service manual) to see how power steering loads are idle compensated for your particular application.
http://www.phpbb.com/
