It is currently Sun Oct 22, 2017 11:55 am
 Post subject: Raise compression
PostPosted: Sat Mar 18, 2017 4:22 pm
Hi! I need help please. how much is safe to cut without ruining valve seats from head to raise compression...i have g13b piston whith 10:1 compression.Tnks!
 Post subject: Re: Raise compression
PostPosted: Sun Mar 19, 2017 12:13 am
About .5mm, but you can cut it on an angle, taking more from the exhaust side
PostPosted: Sun Mar 19, 2017 4:49 am
And the exhaust side how cut?in Romania don't have performant mechanic for cut to ungle...and had gasket avaible here is 1.2 and 1.6mm...
PostPosted: Sat Jun 24, 2017 4:11 pm
Can the compression be raised and it not adversely affect the cam timing?
I'm asking as I would like to raise the compression on a racing engine, but the regs don't allow adjustable cam pulleys.
PostPosted: Sat Jun 24, 2017 5:45 pm
Yes. You can't take that much from the head, but even a little will help compression, and this motor wants compression.
PostPosted: Mon Jun 26, 2017 3:52 pm
How much is the absolute maximum, without affecting the cam timing or piston to valve contact? I'm using oem ukdm gti cams and pistons.
I'm new to the g13.
PostPosted: Mon Jun 26, 2017 3:57 pm
I can take material from the block instead of the head if it yields more compression. As I said, I'm new to the g13 so I haven't had one apart to look at the shape of the combustion chamber.
