http://www.teamswift.net/
Timing Belt Tensioner Pin
http://www.teamswift.net/viewtopic.php?f=4&t=62528
Page 1 of 1
Author:  db [ Tue Apr 18, 2017 10:37 pm ]
Post subject:  Timing Belt Tensioner Pin
Anybody familiar with the pin the sits behind the timing belt tensioner bearing? It appears it sits in the back of the bearing and rides in the track on the water pump, preventing the tensioner from over-rotating. Not sure if mine was lost at some point or if it even had one at all. If anyone has a spare one or even a pic and some measurements, so i can order one up, it would be appreciated.
Thanks,
Dave
Author:  91 ragtop [ Tue Apr 18, 2017 11:24 pm ]
Post subject:  Re: Timing Belt Tensioner Pin
There is no pin. There is a tab on the metal piece that goes behind the bearing. It's the spring loaded adjuster that the tightening bolt goes through.
Ken................
Author:  db [ Wed Apr 19, 2017 8:31 am ]
Ah, that makes sense Ken, thanks for the info.
http://www.phpbb.com/
