It is currently Sun Oct 22, 2017 7:34 am
PostPosted: Mon Mar 02, 2009 9:12 am
Is the GT and GTI fuel rail and injectors the same? I was going to buy a used GT fuel rail for my GTI
Cheers,
Chris
Mini Cooper 1.6 rally car #37
PostPosted: Mon Mar 02, 2009 12:01 pm
A Swift GT and a Swift GTi are *exactly the same car*. Only difference is the "i".
What you are thinking about is the difference between the Swift GT/GTi and the Cultus GTi...
The difference between the Swift/Cultus engines is as follows:
Intake manifold
Pistons
Cams
ECU
If you're looking for a used fuel rail, try and get an MK1 rail, because they are hollow and flow slightly better. Other than that, and GT/GTi rail will work just fine.
PostPosted: Mon Mar 02, 2009 12:47 pm
Thanks! I buying the rail for the injectors and cutting out the factory regulator. So I can pull that tube out.
Cheers,
Chris
PostPosted: Mon Mar 30, 2009 1:31 am
Intake manifold
Pistons
Cams
ECU
:thumbsup:
PostPosted: Mon Mar 30, 2009 4:15 am
mk2 ph1 injectors have a longer nozzle
steve
www.uk-ssgti.com
PostPosted: Thu Apr 02, 2009 5:15 am
Sad but True...
Umm I think a few people said that the MK3 has different injectors than the MK2. The MK3's Injectors are supposed to be the same as the Cultus GTi.
1991 Suzuki Swift GT.
1994 Suzuki Swift GT.
PostPosted: Thu Apr 02, 2009 11:19 am
"Mk3" Swift GT/GTi and Cultus GTi both have the extended injectors, and "Mk2" both have regular injectors. The injectors don't vary from Swift to Cultus, just generation to generation.
PostPosted: Sun May 21, 2017 7:10 am
How can I differentiate by the look of injector which one is from mk2 and mk3 ?? Any differences for example in color?
Which ones are better?
Suzuki Swift GTi mk2 - 131hp and 127Nm
PostPosted: Sun May 21, 2017 9:13 am
Injectors from an mk2 has a green plastic tip. Mk3 has a metal tip.
They flow the same.
2003-EVO7 GT-A
