It is currently Sun Feb 18, 2018 2:39 pm
 Post subject: Mk1 cam timing/degrees
PostPosted: Mon Nov 13, 2017 4:07 pm
Hi.
I have mk1 gti engine in Suzuki Sj410 (Samurais predecessor).
Had problems with bad idle and seems like the cause was badly grinded camshafts(made in Sweden =) ).
That lead me measuring stock cams and results raised a question:
Are mk1 and mk2 cams and timing identical?
According to Catcams.com http://www.catcams.com/products/camshaf ... UP_id=1421
Intake valve should be open 0.5mm @tdc and exhaust 0.7@tdc.
My measurements show that my cam timing is late, intake -8degrees and exhaust -6degrees, with new belt and crankshaft key is ok.
Has anyone else measured stock cams, timing and is there any other explanation than manufacturing tolerances?
And top of this, i just noticed that catcams.co.uk has different specs for stock timing and cams...
http://www.catcams.co.uk/acatalog/Suzuk ... L_16v.html
I was planning to advance both cams ~4degrees but the question is where is the starting point :shock:
PostPosted: Tue Nov 14, 2017 9:31 am
Yes.
Try measuring the timing with the intake centerline method. You should be at about 106 degrees on the intake cam. You can also use the E setting for the intake cam to advance by 4 degrees to re-check your phasing and see if it's closer to where you think it should be
