It is currently Thu Jan 18, 2018 3:20 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Sat Feb 27, 2010 8:29 pm
Great little fixer upper, or parts car. Need some tlc, runs great though. Original engine. No accidents, only one other owner, owned myself 12+ years, also has a sunroof. Only issues are cracked windshield, broken fog lights, rust underneath passenger side and isolated areas. Will need some rubber trim around driver side door around window (seal issue), also a new plastic latch for opening hood (broken off accidentally), some tinting peeling/bubbling on windows. There is some mold inside which can be detailed out/ cleaned but other then that it's a great car and done me well, just been neglected while it was stored. Has had new alternator put in, gaskets, muffler, catalytic converter, O2 sensor, plugs, cables, speedo cable, tires good condition.
Past air care exceptionally well, all inspection results passed. Shouldn't have any issues, result are as follows:
Driving Test:
Vehicle reading/Maximum allowed/Average passing reading
HC ppm 22.00/101.00/21.00
CO % 0.04/1.21/0.11
NOx ppm 3.00/1700/228.00
Idle Test:
HC ppm 12/118/13
CO % 0.00/0.95/0.02
Asking $800.00 o.b.o.
Contact Ken at dajenken@yahoo.ca
PostPosted: Sun Feb 28, 2010 2:34 pm
forgot to mention I replaced all brakes and drums, also had new shocks put in. Just needs new struts.
PostPosted: Sat Mar 13, 2010 1:19 am
How's the frame? Is there much rust and where?
PostPosted: Sun Mar 14, 2010 11:07 am
SOLD
