It is currently Sun Oct 22, 2017 4:26 am
PostPosted: Mon Nov 18, 2013 7:57 pm
99 Chevy Metro - 1.0l 5 speed car - Decent solid driver/project ~101k miles
The bad: located in Rochester NY, so definitely has some rust. Looks decent from 10'. About a year ago I scrapped rust off the control arm mounts, POR 15'd them, epoxied in any holes, primered and painted. Has oil leak, believe to be from front main seal. AC doesn't work. Needs new condenser. Replaced it once already, worked fine for 6+ months, then new condenser developed a leak. Occasional EGR CEL. I just reset with cheap Ebay bluetooth OBD2 adapter.
The good: In the last ~30k miles, all 3x new motor mounts, 2 new driveshafts, K&N airfilter, steering rack & outer tie-rod ends, front wheel bearings, 1 side new rear wheel bearings, fuel pump w/ carrier, rebuilt distributor, control arms, front swaybar end links, front calipers, flex lines, rotors & pads, Radiator & cap, clutch cable, accessory belts, & complete new exhaust including cat. Decent life left on matching tires. Cheap but decent functioning stereo w/ bluetooth. New parts not installed - cam & crank seals, water pump, timing belt & tensioner, oil pan
Also has one of the best shifters you're probably going to find on a Metro - Honda B&M stainless short-throw in a new OEM shifter mount.
Asking $1000 obo - just passed NYS inspection, been driving to work the past week or so.
Email or pm me if interested or for pics.
Dave Robinson superdaver at live . com
PostPosted: Fri Jan 10, 2014 3:29 pm
bump - still available
PostPosted: Sat Apr 05, 2014 9:21 pm
Bump with edits. Email or pm if interested, consider just about any offers. Runs and drives well.
