It is currently Tue Oct 17, 2017 5:48 pm
 Post subject: AWD Gti Swift
PostPosted: Wed Apr 16, 2014 5:54 am
AWD Suzuki Gti - right hand drive
(factory built imported from Japan)
Extremely rare car.
1. Full Whiteline kit - including poly bushes with front caster adjusted, upgraded rear sway bar, Yellow adjustable Koni's all round, King Springs and adjustable front camber bolts.
2. Motor – recent rebuild (2000Kms max) – 75mm Vitara pistons, Spool rods and ARP rod bolts, porting and “clean up” of head, ARP head studs, 1mm oversize SS valves, new brass valve guides, Cultus cams and adjustable cam gears (not 100% on this one).
3. Turbo – Garret T25 with homemade manifold to suit Air conditioning. Cut down truck intercooler and Cultus inlet manifold. Makes around 160HP ATW on 15lbs of boost.
4. Fuelling – Toyota Supra 440 injectors, Walbro pump (accessible via the rear floor now) Magnaflow FPR, braided lines and modified fuel rail.
5. Gearbox – Spring-less HD clutch plate and HD pressure plate with lightened factory flywheel. Gearbox rebuild 2000kms ago, with new bearings, better and later M series internals.
6. Rear diff is still factory standard.
7. Wheels – 16in Sparco Rallies with 195x45x16 Falken tires.
8. ECU – Motec M4
9. Interior: Boost gauge and shift light. Inside “Spotless” – say no more.
10. Other: HID lights, clear indicators, New Swift side indicators, new rear muffler and 2 x centre hotdogs all in stainless steel, no dings, no scratches and no rust.
11. Spares: Rear cradle and diff
Price:$8000AU
Contact Details:Send PM
 Post subject: Re: AWD Gti Swift
PostPosted: Wed Apr 16, 2014 7:57 am
all the cool cars are clear across the globe...... :mrgreen:
PostPosted: Wed Apr 16, 2014 4:21 pm
dammit.. its a very nice ride...
dont forget about shipping cost...
sorry bout my bad english
PostPosted: Thu Apr 17, 2014 11:31 am
Only five more years and it can be imported into the US =)
PostPosted: Fri Apr 18, 2014 7:57 am
That would make an exceptional ice racer for me,as much as I want to go to Australia I don't think I could sneak it home in a suitcase.
Good luck with the sale.
PostPosted: Sat Apr 19, 2014 3:32 pm
an ice racer ? I Feel like putting a jumper on.
Good excuse to take a holiday.
PostPosted: Sat Apr 19, 2014 10:31 pm
Yep ice racing is what makes the winter seem just a little shorter for us,pack warm cloths in the car and ship it all over. :)
An example of ice racing from my awd bike powered geo metro.
http://youtu.be/_AbPkpyLRW8
Users browsing this forum: Yahoo [Bot] and 4 guests
