It is currently Fri Oct 20, 2017 10:12 am
PostPosted: Wed Jun 17, 2015 10:58 am
Selling my 1999 Metro. One owner, never winter driven.
1300cc, manual, 59,600km.
AC, 44mm throttle body with hot water bypassed, stainless exhaust, k&n cone filter, intake heat shield, oil catch can, Apex springs, Koni yellows, greasable swaybar D bushings, energy suspension swaybar endlink bushings, Calmini lower front and upper rear strut tower bars, custom front upper strut tower bar, modified aluminum and ball bearing EG civic short shifter with S2000 titanium shift knob, Sparco pedal covers, Konig Burner 14x6 alloys, Falken 912s 185/60-14 with 90% tread life, Autometer ultralite mechanical oil pressure and vacuum gauge on A pillar, 6k Xenon with hi and low beams, rare rear spoiler, Earl's stainless braided front brake hoses, GT front seats.
Also selling as a package includes:All genuine suzuki parts:
- water pump, timing belt, tensioner pulley, valve cover gasket, thermostat, thermostat gasket, injector o rings and  cushions, pvc bushings x2, front main seal, cam seal, dipstick o ring, cam sensor housing o ring, water pipe o ring, 09283-49002 wheel seal x2, 09283-56002 wheel seal x4, 09283-32040cam seal? X3, 09283-14006 clutch lever seal,09283-48007 wheel seal, 09283-25088 tranny input seal
Used parts: full set of front and rear brake calipers for gti from japan,
Front caliper brakets (from japan), gt front calipers (canadian car), suzuki sport brakepads(1 trackday), oem frint pads, 2 sets of gti rear pads(one set race pads), strut upper mounts, spring plates, strut bearings (new and used, about 6 sets), suspension hardware, brand new passenger side cv shaft assembly, used tranny in pieces, empty tranny housing, 2 sets of front gt knucles, 1.6 throttle body with all sensors, lower steering u joint shafts from japan x2, gt airflow meter, mk2 cluster in pieces, mk3 cluster in pieces, tachometer,  mk3 cluster surrounds from gt with fog switch, various gti and mk5 pcv tubes, factory trim pieces for mk5, stock shifter x2, air temp sensor, tps sensor, map sensors x2, cam sensor, coilover front struts pair, alternator, seat rails, factory mk5 airbox, engine mounts, my sparco seat rails, gti airbox with afm, gt flywheel, more upper spring plates, clutch cable, gas pedal assembly,  brand new set of custom made aluminum crank, waterpump, alternator pullies and alternator braket, switch panel directly bolts onto radio mount that I made for my cultus in japan.
For the complete package with the car, I am looking for $4500.
For pictures, please see my gallery and on this link:
http://m.kijiji.ca/cars-trucks/mississa ... 4556591897
PostPosted: Sat Jun 20, 2015 7:53 pm
Sold to a good teamswift member.
