It is currently Sun Feb 18, 2018 5:12 pm
PostPosted: Mon Nov 23, 2015 10:54 am
94 Swift GT
The Bad
Engine Leaks coolant and minor oil leak
Trans needs replaced (not in car)
Body a little surface rust and one dent in the passenger front fender
Drivers door needs a new regulator
Passenger door need a new handle inside
Dash is cracked
Heater slide switch needs reattached
Rear hatch is off a Geo Metro
I believe the tans has bad bearings. I took the trans out to replace the through out bearing and in the process I noticed the TO bearing spun well. So I spun the input shaft and it had a gravely feel to it.
The engine was leaking coolant fast enough that you would want to check it ever week.
The good
Comes with another engine and trans, They came with the car when I purchased it. I was told they were removed from a good running car that died of rust. However I have never heard them run.
Interior is in good condition
Seats have no rips (could use restuffed) carpet is good along with headliner
Has lowering springs installed
ARE custom wheels
Glass headlights
Extra dent free front passengers fender
Extra set of steel wheels with tires under 1000 mile
Front and rear strut braces
All manuals - owners and all factory shop manuals
Five Suzuki wheel covers
Original hatch with spoiler, good window with defroster and wiper
It was removed because of a large dent that made it not water tight.
The trans went bad about a year ago. I had another engine and trans in another state so I decided I would wait to fix it. Its a year later and I finally brought the spare engine and trans to Florida and now I've lost interest.
I work nights and sleep in the evening so only expect replys in the A.M.
The car is also listed hear on CraigsList Tampa Fl post id: 5328652825
You can see pictures there, Ive always had problems with picture here.
rbudds1@yahoo.com
PostPosted: Wed Nov 25, 2015 1:41 am
Seems like a nice car $1200 for someone that was close by
Craigslist ad
Other cars & motorcycle:
  • 2001 S10 Xtreme
  • 1996 Impala SS
  • 1994 Camaro Z/28
  • 1988 Honda NX650
  • 1980 Honda PA50
Shimaze's cars
PostPosted: Thu Nov 26, 2015 11:00 am
I sent a text three days ago. No response.
PostPosted: Thu Nov 26, 2015 3:39 pm
There are currently two Gts on CL Tampa.
Mine is the one with pictures posted in Brooksville
https://tampa.craigslist.org/hdo/cto/5328652825.html
