It is currently Sat Oct 21, 2017 3:03 pm
PostPosted: Sat Apr 09, 2016 10:41 am
I have a 89 gt with 1.6/1.3 hybrid. The motor ran great only a few thousand miles on it. Trying to sell car to a good home. I have a lot of money in this car and just need it gone.
Motor mods
1.6 block bored to 75.5mm
Wiseco pistons 10.0to 1 compression
Pauter x beam rods
1.6 stock crank polished and checked
All balanced.
Arp main studs
Arp head studs
Ported 1.3 dohc head
New oil pump
750 Cc injectors
Billet fuel rail
Aluminum flywheel 1.6
Spec stage 2 plus clutch
36 - 1 crank trigger
Turbine tech equal length header
Hy35 turbo
2.5 inch exhaust to back of car
Magna flow bullet muffler
Magna flow valve tech muffler
Transmission
98 Hyundai accent trans
Custom axles rated at 550 whp
Cable shifter
Engine bay
Front mount intercooler
Oil cooler
mega Squirt. 3 ecu
Suspension
Front under body brace
Prelude front calibers
15 in swt. Wheels 7 spoke
The bad trans adapter plate broke. Needs a new one built with dowel pins. Needs crank sensor and fpr. The car ran when parked but I used the fpr and sensor for another car. I know I forgot alot of mods. There is a easy 5k in parts but I don't have time to mess with it. 1500 firm. Call or text me 8634099016
PostPosted: Sat Apr 09, 2016 10:49 am
Pics I'm having a hard time finding them in myphone
PostPosted: Sat Apr 09, 2016 11:13 am
I can't get it to take all the other pics I have. But I can text them if you want them.
I forgot to add motor has mls headgasket.
Motor made 225whp 235tq at 8000. Rpm on a mustang dyno with weight set at 3800lb. That was 12psi. These turbos don't get into efficiency until 15 psi plus
