It is currently Sat Oct 21, 2017 3:58 am
PostPosted: Fri May 20, 2016 4:10 pm
Well I have had a blast racing this tiny little light thing for the last two years, but I have joined the dark side and bought a subaru for RallyCross so time for the swift to go.
1994 Suzuki Swift GT 5 Speed
145,xxx Ish miles
Interior mostly gutted, just front seats, Half a dash, and cleaned up all the wiring not used.
I dont think I have even put 100 miles on this thing in the last 2 years, was strictly a once a month Rallycross car, and ran two autocrosses with it.
Engine:
Original 145k mile 1.3 Twin Cam
Less than 100 miles on Valve/head Job new head gasket/waterpump/fuel pump/plugs/cleaned up the lash adjusters/timing belt. Cant remember if it got 3 or 4 valves replaced due to burning.
Suprf1y 3 Tech 222/365 Cams
Installed a quick replacement socket in the ECU and currently has a Toms 2 Rally chip
Still full stock exhaust system and stock intake
Transmission:
Balli (member on here) Helical Limited slip with preload washer installed for tighter lock up for dirt racing (Wow this diff grabs tight when it needs to and still lets you turn just fine when you dont need the lock)
Other than that the transmission is stock.
Clutch brand new, less than 15 miles
Body:
Not rusty and not really dented up, but paint is....very rough haha
Extended lugs on all corners and changed to more standard 12mm x 1.50 instead of goofy 1.25
Whiteline bushings in the front, added caster, and camber bolts.
Full "Phoni" suspension haha (from thread on this site). Original struts have 25w oil in them, and 1998 swift springs cut on all four corners
The bad:
Last time I drove it I noticed the pass side axle seal leaking.
In the last 2 years it has only done this 3 times, but once its hot it will hesitate and buck under load, could be fuel pressure regulator, could be TPS I dont know. But comes with aftermarket adjustable fuel pressure regulator.
I have a clear blue Texas Title in hand, but i always trailered it or flat towed it so it is not titled in my name.
Comes with:
4 white aluminum 14" wheels with Snow Tires mounted (Think budget rally tires) and one spare tire
4 14" Aluminum Celica Supra wheels (wide ones) With standard maybe sporty street tires 185/60/14
2 14" Aluminum Celica Supra wheels (wide ones) With Falken azenis 195/60/14 Autocross "Slicks" 200 Treadwear (Real old but they still carve way better than the street tires)
Flat tow kit- Hook up to back of your truck and drive off with it
Stock rear seats
Extra gauge cluster
2 extra distributors
Extra front wheel bearing
Extra whole drivers side Axle/cv
I think thats about it
Asking $2,000 and pretty firm right now, Might be a good price, might be insane, I really dont know, but if it doesn't sell I will just end up parting it out.
Any questions feel free to ask
Located in central texas
PostPosted: Fri May 20, 2016 11:37 pm
PM Sent
PostPosted: Sun May 22, 2016 9:26 pm
Did those 222/365 cams make much difference ?
Ken..............
PostPosted: Thu May 26, 2016 11:55 am
Yea the cams made a difference, screams in the top end, if I was to do anything I would look into some cam gears to move the power down slightly from the top end to mid range.
Now the limited slip made the most insane difference
PostPosted: Thu Jun 16, 2016 6:51 pm
Pm Sent!
PostPosted: Fri Jun 17, 2016 8:48 am
Pm send
PostPosted: Sun Jun 19, 2016 3:56 pm
replied to all PM's
PostPosted: Sat Sep 10, 2016 2:17 pm
I am in texas and want this car. Message me. I already PMed.
