It is currently Mon Nov 20, 2017 6:37 pm
 Post subject: cams for 1.3l sohc
PostPosted: Sun May 19, 2002 6:02 am
just wondering if the group a cams for a gti will fit in a 1.3L sohc?? <p></p><i></i>
 Post subject: Re: cams for 1.3l sohc
PostPosted: Wed Sep 04, 2002 11:56 pm
Of course they wont one has 2 cams and one has one guess wich one has each. Any way if ya want a cam and your in Austrailia contact suzisport<br>www.suzisport.au.com <p></p><i></i>
PostPosted: Mon Sep 16, 2002 1:31 am
I've got a cracked head with good cams for a G13B SOHC. I'm in New Zealand, if you wan't them, you can probably have them, if you are interested. <p></p><i></i>
 Post subject: computer mod
PostPosted: Tue Sep 17, 2002 7:15 am
anybody heard of this: they can modify any computer.<br>they said it will be $399.00 u.s to remap my fuel with a 7 hp gain. is that worth $400.00 dollars?!<br>address is communications@fullLogic.com <p></p><i></i>
PostPosted: Mon Jan 06, 2003 11:09 pm
Senior Member
Are these cams still available???<br>Mike. <p></p><i></i>
PostPosted: Tue Jan 07, 2003 12:47 am
Senior Swift Guru
eeprom editing isn't new and it needs to be done on a dyno and real-time to be worth it. Make sure your ECU has a chip in it (are you SOHC or DOHC?). Do you know what equipment they use? 7 hp is a weird claim as I don't see the fuel curves giving those kind of gains. The benefits are usually in changing both timing and fuel maps and yes it can make gains if the tuner knows what he is doing. You have to be careful as some less experienced tuners will go for that extra hp over safety. <br><br>$400USD is actually cheap for a custom properly built chip that was tuned on a dyno and real-time. It can take 5-7hours of continuos testing real-time to see the kind of gains all the way accross the power band to make it worth it. It is better matched if you have lots of mods or plan to make lots of mods. Is it worth it if you have SOHC? not terribly. You could put that money towards DOHC and make 30hp. <br><br>If you have DOHC, go with the chip Tom has. Some software nerd spent a lot of time making it once upon a time, and you will see gains from it. For hte money you can't compete with the time that was invested by someone in this chip.<br><br> <p><br>Kyle Jones <!--EZCODE BOLD START--><strong><br><br><br>Your friendly TeamSwift Op.<br><br>Junk-Yard Turbo set-up, formerly NOS-fed 1989 Suzuki Swift</strong><!--EZCODE BOLD END--></p><i></i>
 Post subject: ha!
PostPosted: Tue Jan 07, 2003 8:17 pm
thats back when i was a newbie with a SOHC!!<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>dont make fun of me! j/k <p></p><i></i>
 Post subject: Re: ha!
PostPosted: Wed Jan 08, 2003 9:43 am
Hey N......I don't think they made a G13B SOHC engine!! <p></p><i></i>
PostPosted: Wed Jan 08, 2003 10:32 am
The G13B stands just for the block!!! It comes in samurai and swifts,no matter if it is a SOHC or DOHC (gti) G13B is just the BLOCK. An sohc and dohc engine uses the same block, just the internals and the head changes.<img border=0 src="http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif" /> <p></p><i></i>
PostPosted: Wed Jan 08, 2003 4:59 pm
Hmmm I guess you learn something new everyday...or maybe it's just a missunderstanding...I dunno!<br><br>Jake <p></p><i></i>
PostPosted: Thu Jan 09, 2003 6:17 am
Oh btw the balenos 1.3 also uses the G13B block.<br>That's why i buy those motors,sell the rest of the parts and keep the blocks por spare.<img border=0 src="http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif" /> <p></p><i></i>
PostPosted: Thu Jan 09, 2003 12:39 pm
Senior Swift Guru
not a misunderstanding...<br><br>I've seen other designations used by companies to help designate each individual motor according to heads. Not sure where they came from (just made up).<br><br>i.e. <br>G13BDOHC - G13K<br>G13BSOHC 16valve - G13BB<br>G13BSOHC 8 valve - G13BA<br> <br>Are there actually Swifts with a stamped block that says G13A on it?<br><br> <p>-Kyle Jones <!--EZCODE LINK START--><a href="http://www.angelfire.com/de/ksj/myswift.html"><br><!--EZCODE BOLD START--><strong> Junk-Yard Turbo set-up, formerly NOS-fed, constantly evolving 1989 Suzuki Swift GTi</strong><!--EZCODE BOLD END--><br></a><!--EZCODE LINK END--><br></p><i></i>
 Post subject: Re: G13A??
PostPosted: Thu Jan 09, 2003 1:18 pm
Nope never heard of or seen those. <p></p><i></i>
 Post subject: cams
PostPosted: Fri Jan 10, 2003 11:15 am
Paeco say they can grind cams..you should get it when their done in a couple years! <p></p><i></i>
