It is currently Tue Oct 17, 2017 3:24 pm
PostPosted: Sat Jul 22, 2006 8:45 am
I deleted your post in the product review section. Don't double, and triple post again.
Are you saying that you have a 3cyl. with coil packs, and no distributor?
I've never seen that before. If you can't reset the ignition timing, I wouldn't think you'd get the benefit.
PostPosted: Mon Jul 24, 2006 11:20 am
Use the E setting on the stock sprocket. That will give you +4 degrees. I can mod one for you, if you want more.
