It is currently Tue Feb 09, 2010 5:19 am
 Post subject: SOMENDER-SINGH grooves
PostPosted: Mon Jul 21, 2008 5:14 pm
Ok i have done a lot of looking on Teamswift & other places. I have found a lot of pros very few cons! I have only seen a couple of post on this sight on positive feed back! Not much for negitive feed back! What is your take does it work or not!
Any real experiance with the grooves! Thanks John
96 Geo Metro 1.0 3cyl
70 Ply Cuda 440 500hp don't ask!
71 Ply Roadrunner 340 10-14 mpg
95 Chevy Truck 6.5 chipped 18mpg
08 Chevy Impala 32mpg
 Post subject: Re: SOMENDER-SINGH grooves
PostPosted: Mon Sep 01, 2008 9:13 pm
i cut them into the head on my 3cyl i just rebuilt. this will be the first motor i've tried them on. so far plugs look perfect. i'll log a few thousand miles and see if I can get my hands on a bore scope and post some pics from inside.
if you have a motor opened up already i figure wtf why not? i wouldn't go ripping apart a good running motor just to do it tho.
i might do them on my 383 efi'd SBC thats going in my camaro as we well (next build)
PostPosted: Tue Sep 02, 2008 10:04 am
can these groves be 'home-made' or should they be done in a shoop ?
 Profile Personal album
PostPosted: Tue Sep 02, 2008 11:22 am
I put some in my head, then decided against it due to the rough/sharp edge you can create with it. so I gutted them all out and rounded it flat. I didnt want any detonation. However, if you just do one and dont go very deep, maybe you can get something. I sure wouldnt tear apart a good motor just to do this mod though.
the lolcar family
PostPosted: Tue Sep 02, 2008 11:39 am
http://somender-singh.com/content/view/133/37/
COMPLETE 3banger TBI TURBO SETUP FOR SALE!!!LOWERED PRICE - $700 FOR EVERYTHING TURBINE TECH MANIFOLD!!!
Check the F/S thread for other stuff.
PostPosted: Tue Sep 02, 2008 12:18 pm
see in that article, those grooves look too deep, the edges on either side of the "valley" are raised portions that have significantly less cooling through the rest of the head since a bunch of the surface is removed, in a very hot combustion chamber, these portions left sharp on either side of the cut could act as glow plugs.
I think time/money is best spent elsewhere on the head
this is what I ended up with after I wasted that time cutting them, I had to grind them all out
the lolcar family
PostPosted: Tue Sep 02, 2008 2:18 pm
This is the first time I've seen you post anything on your attempts at "Somender Singh grooves" - I have to assume that they don't work the way you expected - perhaps that was because of how you did them - as I recall the grooves you cut were distinctly different - two grooves, closer together leaving a "tooth" in the middle - much more likely in my opinion to act like a glow plug.
Why not post pictures of your attempts here and let everyone see how you did it.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Tue Sep 02, 2008 2:51 pm
I had posted them in a few builds and did the reading after, then a few guys suggested they act like a glow plug (like I did) and thats why I cut them out. I dont really have anything else to post, I suppose ill post a few pics from in between in a few stages
I ran it like that for a little while, but eventually pulled the head and did a little more prep work for 20+psi
I cut them like this... which you shouldnt do or youll be cutting the out
the pic I posted in the last post is what im running right now, and looks optimized to me. I spent a little while in there smoothing things. I dont have dished pistons anymore and shaved alot off the head means im running high compression like 11.0+ so I tried to remove what I could in an optimized way. thank god that was only a 3cyl head wow. I removed alot of material in the exhaust side port and put a big manifold to a bigger turbo
the lolcar family
PostPosted: Tue Sep 02, 2008 6:42 pm
Here's how the other guy did his ...
his own has a lot more material in between the slots with a lot of conductive area to conduct the heat away.
Geo_Head_Groove.jpg [ 45.29 | Viewed 1162 times ]
'93 1.3 Swift GLX
PostPosted: Tue Sep 02, 2008 7:49 pm
and if I were to attempt them again thats probably how I would do it. But there still is sharp edges on either side of the cut. especially the point created at the left cut
the lolcar family
PostPosted: Tue Sep 09, 2008 9:33 pm
from my reading and understanding you are going for flame propegation and reliefe from suction created by quench areas. it would seem that one deeper, smoothed and dialed in groove would do better than just a bunch of sharp edge slits cut in the head.
there are pics of mine posted on here... mine extend all the way to the edge of the combustion chamber and started as deep as the top of the dome.
i've only got 200 miles on my combination and that is with no front end to help with aero. in a few weeks i'll post mpg results.
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
