It is currently Sun Oct 22, 2017 4:18 am
PostPosted: Mon Sep 22, 2003 10:44 pm
I wanna know which are the differences between the SOHC and DOHC engine. And how can i know which one is mine?
Luis Lau
PostPosted: Mon Sep 22, 2003 10:55 pm
smart@ss
SOHC means single camshaft, Dohc means double camshaft. What year is your car? Is your car carb or fuel injected? what does it say on your valve cover? if you got sideskirts then more likely than not your car is dohc.
I miss Jomo BRING JOMO BACK
mojojoeyjojo wrote:
PostPosted: Mon Sep 22, 2003 10:58 pm
I still dont know which is my car.
I just know is a Suzuki Swift 1.3L Sedan 1992
Luis Lau
Lima, PERU
PostPosted: Mon Sep 22, 2003 11:05 pm
smart@ss
it's sohc.
Welcome to the board 8)
PostPosted: Wed Sep 24, 2003 7:00 pm
Are sure?
I thought u r right, but i have check this page:
http://www.carfolio.com/specifications/ ... ?car=85976
That seems to be my car.
Anyways, is there any physical way to find out that. Maybe some sight in the car or maybe push the throtle and count time to get to some speed.
My car is fast, my dad told me that is really fast. I know this, cz i was asking him to teach my bro to drive, but he denied cz is to fast to learn.
PostPosted: Sat Sep 27, 2003 4:59 pm
hey is there any way to swap the head or get a DOHC i have a 1.0L SOHC is there anyway i can drop in a DOHC???
Let me know
~RiZ~
PostPosted: Sat Sep 27, 2003 8:26 pm
The mad quebecer
The mad quebecer
Any good machining shop could build you a complete and functionnal DOHC head for your 1.0l. Are you ready to spit $5000 on it?
PostPosted: Sat Sep 27, 2003 8:51 pm
smart@ss
Let me know
~RiZ~
if you're talking about swapping just the cylinder head, then I don't think it's possible, the blocks are diff. and have diff. bolt patterns. But if you'retalking about swapping the whole engine ( block+head) then HELL YEAH, it's possible , doable and recommneded.
PostPosted: Tue Sep 30, 2003 2:43 pm
i want to do an engine swap but its a lot of money and i have a turbo on the 3 cylinder and i wouldn't want to loose that... i also have the underdrive and cam gear for it, machine balanced crank and blueprinted forged rods. so i don't know if its worth it.
however i think my piston rings are fried... how would i know.. i have a lot of blow by now..
PostPosted: Tue Sep 30, 2003 8:20 pm
Check your compression.Alot of blowby would indicate bad rings.If you need any assistance with your motor,I can help,if you want.Don't take it to a shop and get hosed.Re-ringing one of these motors is not a big deal.
