It is currently Sun Jan 21, 2018 6:51 am
 Post subject: For you 8 valvers.....
PostPosted: Sat Nov 01, 2003 10:17 pm
samurai and non gt swift have the same engine and head
(except for the intake) so here go some supplies from http://www.roadlessgear.com
Quantity in Basket:none
Code: RGE100
Price: $75.00
Shipping Weight: 7.00 pounds
Model: <Select One>Power Cam 260 Power Cam 272
Refundable Core Charge: $30.00
Strap yourself in and feel the G's, baby!
When you need serious power gains - try one of our professionally ground cam shafts. These cams are manufactured by a company who has been specializing in this for over 20 years now. Available in your choice of two different grinds:
Power Cam 260 - Low to mid range performance. Increases power in the Idle thru 5200 RPM band.
Power Cam 272 - High range performance. 1800-6000 RPM.
For 1.3L Suzuki Samurai.
Note: this product requires you to exchange your stock regrindable cam. There is a $30 refundable core charge.
Roadless Gear Power Cams (Billet)
Code: RGE110
Price: $125.00
Note: this product does not require the exchange of anything other than money. Brand new and constructed from heavy duty materials that exceed factory tolerences.
Adjustable Cam Sprocket
Code: RD100
Price: $129.00
Shipping Weight: 3.00 pounds
Select Model: <Select One>1.3L Samurai 1.6L Sidekick 8 Valve 1.6L Sidekick 16 Valve (+$10)
This adjustable camshaft sprocket allows you to fine tune your motor your way. Easily adjust your camshaft timing to gain power in either the low or high RPM range. Includes built guide indicating degrees of retardation or advance. Each degree you retard your camshaft by will increase your power band by 200 RPM. Each degree you advance your camshaft by will decrease your power band by 200 RPM. Made from billet aluminum and available for either 1.3L Samurai or 1.6L Sidekick motors.
Underdrive Crank Pulley
Code: RD110
Price: $49.00
Shipping Weight: 2.00 pounds
Increasing power can be as simple as swapping a pulley. This 100% billet aluminum pulley weighs much less than the cast stock pulley - plus it's 18% smaller. This underdrive will turn the alternator and water pump with less resistance and gain otherwise lost power back. Available for either 1.3L Samurai or 1.6L Sidekick motors.
Direct Hits
Code: DH100
Price: $155.00
Choose Model: <Select One>Samurai & Sidekick 8 ValveSidekick 16 Valve (+$40.00)
Each kit includes:
* DirectHits current peaking capacitors - 1 for each cylinder
* High energy wireset
* Premium non-resistor sparkplugs
* Installation tool (plastic 3/4' 12 point 1/4' drive socket to install the DirectHits properly to 12 inch/lbs of torque)
* Dielectric grease for all electrical connections
* Installation instructions
* Installation advisory - do's & don't's and hints
* DirectHits Decal
You have our promise that these things really do work. Try a set today and if you are not happy with them - we'll refund your money. Simple as that.
PostPosted: Sun Nov 02, 2003 8:56 pm
The camshaft prices are not a bad deal.
PostPosted: Sun Nov 02, 2003 9:28 pm
if you have an exhisting cam to regrind you cant go wrong with $75
PostPosted: Tue Nov 04, 2003 4:49 am
Those cams won't work on cars because they have a dist. gear on the end.
PostPosted: Tue Nov 04, 2003 7:40 am
The regrinds will.
PostPosted: Tue Nov 04, 2003 10:51 am
Ye they will, but will throw your rocker angles way out and cause premature wear. For racing OK, but for a daiily driver maybe not.
PostPosted: Sun Nov 09, 2003 4:11 pm
What about the Pulley and cam gear, will those work with the 8valve engines????
PostPosted: Sun Nov 09, 2003 8:48 pm
Cam sprocket would work, but the pulley I'm unsure. I don't have a swift to look at. Do you have a v-belt or a micro v-belt? I'm pretty sure Rotational Dynamics has you covered either way.
PostPosted: Sun Nov 09, 2003 11:00 pm
I have no idea about what belt i have, i can take a pic tomm and upload it and you could tell me
PostPosted: Sun Nov 09, 2003 11:10 pm
Has anyone ever bought any of these products and installed them on a 8valve swift/metro??? If so how hard are they to install?
 Post subject: pulley
PostPosted: Tue Nov 25, 2003 6:17 pm
i have one on my 1997 1.3 merto and on a 1999 1.0 . and you can feel it rev faster . it does not help much on an auto trans. 1.0.
but a cheap and easy swap. i got mine off of EBAY.
larry
PostPosted: Tue Nov 25, 2003 6:43 pm
check the sticky in this section called underdrives .. adam/bigbearzuke has them, they're quite easy to install.
