It is currently Tue Jan 16, 2018 11:13 am
PostPosted: Fri Feb 12, 2010 3:50 pm
I have a 1993 GEO METRO, Canadian assemble. I am having a hard time finding a transmission mount GM part # 30009343. They have discontinued manufacturing this part, kindly help me and locate this part.
thank you
PostPosted: Fri Feb 12, 2010 6:37 pm
what motor and trans ????
PostPosted: Fri Feb 12, 2010 6:39 pm
http://shop.oreillyauto.com/ProductList ... 27&PTSet=A
PostPosted: Fri Feb 12, 2010 7:14 pm
1993 Geo metro, XFI. 1.0 Automatic transmission. Two door hachback. Assembled in ontario, canada
PostPosted: Fri Feb 12, 2010 9:16 pm
the XFi never came in automatic :huh:
08 Civic Wife's car
PostPosted: Sun Feb 14, 2010 7:49 am
Hence, the difficulty finding mounts. :lol:
PostPosted: Sun Feb 14, 2010 5:37 pm
yes, we do have an automatic transmission on my Geo metro XFi. 1.0 the transmission mount is different than the one available at teh spare part shops. Kindly, let me know where I can find auto transmission mount. Thank you.
PostPosted: Sun Feb 14, 2010 7:01 pm
manufacturer: part#
westar EM-8314
thats the only tranny mount i can find.
08 Civic Wife's car
PostPosted: Tue Feb 16, 2010 1:54 am
I'd say, that XFi isn't an XFi but a badged one.
Any engine mount from the same spot on a 3 Cylinder 1989, 1990, 1991, 1992, 1993, 1994 Geo Metro with the autotragic transmission will do the job.
Technically speaking as well, it's not called an engine mount, but a Torque Strut Mount for the Auto trannies.
Go to http://www.rockauto.com go to the part number search and look for:
Anchor #8658
A true Xfi was 1.0L 3cyl, 5sp manual, 3 dr hatch. Unless someone swapped out the tranny and basically threw away all of the MPG, 55 to at the very best of 40... I have a dealer badged GT. 8)
My cars:
PostPosted: Sat Mar 02, 2013 6:47 pm
That part you speak off is also suzuki part # 11620-60E21 and is no longer available in the USA or Canada. You can get them in Jamaica (US$60) or what I did was use a Nissan Mount (had to search for the right diameter and thickness) and cut out the old one and insert the Nissan one into the bracket and clamp and weld it back.
Anchor #8658 is NOT the part you are seeking.
westar EM-8314 is NOT the part you are seeking.
Is this the photo of your part?
File comment: Photo of part
PostPosted: Sat Mar 02, 2013 11:29 pm
Since the guy was only on here two days, (and almost 4 years ago) I doubt you are going to get a reply. However, it was nice of you to try and help.
FYI :
- there are NO automatic XFI's.
- He lists his location as USA, so he's pretty unreliable or super paranoid.
-his is either an MR model with an XFI badge on it or an MS model which has been converted to auto.
-MS and MR are two letters in the VIN, right?
If this fly by night member is still out there, "bunny" (which I doubt), thanks for joining, asking a question and leaving...(mostly the last part).
PostPosted: Sun Mar 03, 2013 12:09 am
I did it for others in the future as it took me a while to find that part for myself and 2 other cars that needed it over the past 2 years. I have found this forum to be an absolute wealth of knowledge even for older posts.
PostPosted: Mon Mar 04, 2013 12:40 am
sometimes it never hurt to bring post's back from the dead.
