It is currently Tue Oct 17, 2017 10:07 am
 Post subject: vacuum advance
PostPosted: Wed Sep 15, 2010 5:55 am
can someone give me the heads up: is the vacuum advance on the distributor supposed to have ported vacuum or manifold vacuum going to it?
vehicle: 1996 suzuki swift cino g13ba 1.3 carburetor powered sohc engine manual trans.
Robert.
 Post subject: Re: vacuum advance
PostPosted: Wed Sep 15, 2010 10:25 am
I vote ported.
PostPosted: Thu Aug 25, 2016 6:24 am
Hello.
I have same engine. Distributor http://natrim.ru/td2.jpg But vacuum advancer Denso is as at foto http://natrim.ru/td3.jpg Is it genuine? Where to connect the second tube? The first - in the carburetor.
I have not good Suzuki catalogue to get optimum part number to purchase genuine vacuum advancer. Please, get part-number and/or link to the catalogue.
