It is currently Tue Oct 17, 2017 3:35 am
 Post subject: Econo Head package
PostPosted: Fri Oct 12, 2012 6:25 am
Hello,
My name is Britton I have a 96 geo Metro 1.0 litre. I need to rebuild the motor and i want to send my head to 3tech, but i am unsure of what package to get. My dad had the performence cam installed in his and he loves it but his idle on his car is screwy and i dont want mine to be like that. So i am just creating this post for some people to give me some feed back on what you think is the best package for me to get. I would like some more power in my little geo lol. But i will tell you the type of drving i do, i usr this car for commuting to work everyday i drive 75 miles one way. So if you guys can give me some more info about the econo and performance packages thaat would be great thanks.
 Post subject: Re: Econo Head package
PostPosted: Fri Oct 12, 2012 11:44 am
This might help
FAQ.pdf [143.03 KIB]
Downloaded 168 times
PostPosted: Fri Oct 12, 2012 2:15 pm
Thanks for the info it did help. Now what i would like to know is if i went with the econo package for my 96, would i loose power, increase a lil or will it stay the same it is now which is stock, because if i loose i def dont want the econo pack. Let me kno please and thanks again for your help.
PostPosted: Fri Oct 12, 2012 3:10 pm
Power should remain about the same, maybe a bit more, but torque will go up.
PostPosted: Tue Oct 16, 2012 5:59 am
Ok doesnt sound to bad, is that a good thing for the torque to go up. Do you recommend getting the econo package
PostPosted: Thu Mar 14, 2013 7:44 pm
I don't mind the idle. Give it a little love in the basic tuning department (timing, idle etc) and as long as your IAC is working, its fairly stable at least with the stage 2 cam (350/218) and a +8 sprocket. a little lope-e-ness never hurt anything. if you are stopped idling long enough to annoy you, shut the engine off.
I'll be posting a youtube clip here shortly of the idle and rev sound just because it comes up a lot.
stick with the stock clutch or the stock 1.3L clutch/flywheel. I went with the 1.3 but got a stage 4 puck clutch and it does not like to be granny feathered at all (like you would do in bumper to bumper driving)
more tq is always a good thing.
