It is currently Tue Oct 17, 2017 4:04 pm
PostPosted: Thu Jan 24, 2013 11:12 pm
Alright. family members 90sprint is having a problem. had recent timing belt change when he first bought it so unknown if problem was there before the change when it broke. problem is it will run great at lower rpm fine lots of power until you rev it up. probly past 3500 it will sputter and will keep sputtering at any rpm after. if it is allowed to idle it will run ruff and stall. restart and it continues to run ruff it has happened a couple times to him and im going to be coming up to some time soon that i can look at it.for him. just wondering if anyone can give some assistance to what i should be checking right off the bat.
1990 faded red turbo firefly project car
1990 sidekick 3" lift 31" mt's
2006 YZF600 screamer. my summer toy/daily driver.
PostPosted: Fri Jan 25, 2013 1:54 pm
First thing I would check is the timing belt. Sounds like it could be a tooth off.
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Fri Jan 25, 2013 9:25 pm
also check fuel filter/fuel pressure. when an engine wont rev that could also be a fuel issue. what shape are the plugs, cap and rotor in?? also check compression.
PostPosted: Sat Jan 26, 2013 4:54 am
All relevant but I would go with the peanut gallery :P and check the belt/gear alignment first.
Am I right, it's been doing this since he got it, or is it intermittent?
PostPosted: Sat Jan 26, 2013 9:42 pm
peanut +2
t3 ragtop wrote:
suprf1y wrote:
jrjd wrote:
PostPosted: Sun Jan 27, 2013 3:03 am
peanut, +3
if he ahd a backfire thru the intake when the belt went it may have knocked out the map sensor. or at least knocked the vacuum hose off.
PostPosted: Wed Jun 12, 2013 10:58 am
My 1993 G10 was idling roughly, finally died and would not start again. The culprit? A widened IG fuse socket (probably from 20 years of high ignition current) made the fuse have a very poor connection which eventually failed. Probably not the same failure as your car, but easy to check.
image_id: 22939
The fix? Don't bother trying to push the contacts back together: they won't go. Just bend the fuse blade a bit so it fits snugly into the widened contacts.
