It is currently Sat Oct 21, 2017 12:57 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: oversize pistons
PostPosted: Tue Feb 19, 2013 1:24 am
I have Been looking for reasonably priced oversized pistons for a 1.3 8 valve (1996). I called all the local stores and shopped online for a couple days. And all i can come up with is stock bore and then srd forged (way over my budget).
Does anyone have a line on some pistons? Or point me a direction? Thanks
GEO MAFIA!
14 ford Mustang v6.
 Post subject: Re: oversize pistons
PostPosted: Tue Feb 19, 2013 4:27 am
What year engine is that? I have a set of 2nd hand flat top pistons, 0.5mm oversize, they are out of a early 1.3 sohc 8 valve engine.
US$65 + postage From NZ if you want to try them.
PostPosted: Tue Feb 19, 2013 9:18 am
We really need to keep compression down because its turbocharged. Also we want to bore it like 2mm over. Id like to use vitara pistons but i cant find enough solid info for the 8 valve vitaras and how they effect compression.
If anyone has info on vitara pistons that'd be helpful too.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Wed Feb 20, 2013 8:15 pm
Did a lot of searching and contacted Jard at turbine tech, my results are that vitaras arent practical and forged isnt cheap. I called wiseco but they were closed. I searched rockauto.com and found some sidekick pistons that are 40 over, which should be 76mm.
Are the pin heights the same on the 1.3 and 1.6? If so i might use stock g16a pistons
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Feb 22, 2013 4:25 pm
You need Sidekick pistons G16K . I've been using them in my Mk1 T3 for 100K miles . They have floating pin so if your car has pressed in pin you will need either GTi or T3 rods for them. I think that valve cut outs are in correct place to keep it non interference. Also they are 75mm I think stock pistons are 74mm so if you bore it out to 76mm that's .80 over . Don't think there is room for that ..........
PostPosted: Fri Feb 22, 2013 6:04 pm
what engine are you working on?
i keep advising you guys to list your engine type in your signature line so that it's right there for anyone willing to reply in your threads to see.
stock pistons are 74mm. you can bore the cylinders over to 75mm, or a 40 thousandths over bore and still maintain a nominal liner thickness. a 76mm bore would result in paper thin bore liners.
when i was building my lil' black monster turbo3 i used the vitara pistons that jard sent to me and that engine turned out pretty neat.
PostPosted: Fri Feb 22, 2013 6:43 pm
@ssclown
I have thought about using studs it looks like you went with studs any advantage to them ?
PostPosted: Sat Feb 23, 2013 12:29 am
superior clamping and reduced thread stresses on the block.
i hate it when the 4 exposed head bolts start looking like rust balls and here in the rust belt it only takes a year for the heads of those 4 bolts to look like hell. i had my head bolts made from 17-4 stainless alloy that has a higher tensile strength than grade 8 or 10.9 hardware and never rusts.
i also use a2 stainless studs and flange nuts on the intake and exhaust manifolds and a2 stainless socket head hardware to assemble the engine. after putting a lot of effort into building an engine the internals are hidden so i try to make the outside special, too. :wink:
PostPosted: Sat Feb 23, 2013 11:04 am
The engine info was in the first post. Anyway thanks for pointing out the sleeve thickness. I was thinking they were the same but the g16 was just bored by bigger.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Feb 23, 2013 12:41 pm
sledgehammer wrote:
my point exactly. any reader that joins the thread later than the first post would have to go looking for the information rather than to see it in your signature line in every one of your posts.
you can also go to the user control panel to add the information to the line under your avatar which would make your engine type immediately available to readers.
PostPosted: Sat Feb 23, 2013 8:05 pm
http://www.ebay.com/itm/86-95-Suzuki-Sa ... 53ea0b1848
just a quick look at my list of suppliers. i'm sure that you can find others. i've had several transactions with this merchant and they are okay by me. :wink:
PostPosted: Sat Feb 23, 2013 9:56 pm
@ssclown
Thanks for all of the info i found these
http://www.ebay.com/itm/89-99-SUZUKI-SA ... 90&vxp=mtr
PostPosted: Sun Feb 24, 2013 2:01 am
Fixed.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Feb 24, 2013 10:52 am
yummy, that's another parts house i have bookmarked. i've dealt with cns auto parts, too.
they're okay, as well. :wink:
PostPosted: Sun Feb 24, 2013 12:43 pm
@ssclown
Good to know. My goal is not to cheap out on the parts. I'm planning on buying that set or one just like that. Here is another goof ball question. Will the connecting rods from my G10 1.0 work with the Pistons i posted a link to?
Thanks
PostPosted: Sun Feb 24, 2013 2:54 pm
Yes, but the pin height is different so you will have to machine some material off the top for zero deck height, or deal with the extra compression. I'm going to guess that it might be close to 11-1
PostPosted: Sun Feb 24, 2013 9:19 pm
@ssclown
Good to know Mike I would like to avoid taking anything off of them if possible.Any advice on over coming this and still bore them out .
PostPosted: Mon Feb 25, 2013 9:13 am
What are you trying to do with your G10?
PostPosted: Mon Feb 25, 2013 10:42 am
@ssclown
Simple answer is more than Suzuki intended to with it. I want to pull as much HP out of it as possible I'm not concerned about Gas mileage. I will have the engine out soon so I'm gathering all the parts necessary and asking as many dumb questions as possible so that i have my ducks in a row when the engine is on my stand. I had considered boring it out but i was not sure how far i could go before i needed larger pistons. When it's all said and done i may just hone the cylinders thats if boring them out is not worth the time or money.
PostPosted: Mon Feb 25, 2013 11:12 am
Do a test fit. They might work ok, as long as you measure the deck height and verify it first. I was after zero deck, but you may be able to have it stick out of the deck .010" or so.
PostPosted: Mon Feb 25, 2013 12:47 pm
@ssclown
Thanks i will measure it.Nothing is more frustrating then completing the build and having things go south after all the hard work.I do have a engine on my stand right. Now so i may play with that one first.
PostPosted: Mon Feb 25, 2013 12:49 pm
@ssclown
Did you have issues with the pistons sitting to high?
PostPosted: Mon Feb 25, 2013 7:25 pm
i used them for rings, bearings, gaskets, brake components, timing belt kits, water pumps, and oil pumps.
i have never bought pistons from them. :wink:
PostPosted: Mon Feb 25, 2013 9:21 pm
@ssclown
ok got it.What Pistons did you use?
PostPosted: Tue Feb 26, 2013 7:25 pm
You can get .020 and .040 oversize from partsdinosaur if you're OK with cast pistons.
Ken.....
