It is currently Fri Jan 19, 2018 8:11 pm
 Post subject: Valve clearance?
PostPosted: Thu Mar 14, 2013 3:33 pm
I'm looking to check and adjust and set my valves on my 90 1.3 sohc what's the hot and cold clearances for intake and exhaust valves? Thanks
 Post subject: Re: Valve clearance?
PostPosted: Fri Mar 15, 2013 1:27 am
.006 intake .008exhsust
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Mar 15, 2013 1:39 am
No sticker under the hood?
PostPosted: Fri Mar 15, 2013 3:17 pm
Hood was replaced with a aftermarket oem one no Sticker under hood, Thanks too all who replied will see how it goes this weekend doing a timing belt job cam seal and crank seal cover seal and pan and valve adjustment!
PostPosted: Fri Mar 15, 2013 6:29 pm
Hansolo is one of the best valve adjusters here on the forum for your type of engine.
He has a special technique that he used on our '94 SOHC.
It sure quieted it down.
Maybe he'll chime in.
Either way, here's hoping you end up with a power plant and NO leaks.
You might want to look for a spare under hood sticker.
They've got all kinds of neat information that might come in handy, or so I've been told.
Come to think of it, the only reason we pulled this hood
was to swap in a hood with the correct sticker for the car.
