It is currently Sat Feb 24, 2018 9:48 am
PostPosted: Tue Apr 09, 2013 3:55 am
Does anyone know if there's a confirmed way to tell the difference between tachs without installation or dismantling?
I have one that I've been running that I'm not 100% positive is from a 3 cyl and one that I just picked up that I am sure came from a 3 cyl and a third from a 95 4 cyl.
A couple differences I found:
-underneath the input for the speedo cable is a number 2, to the left, mirrored and upside down is a number. The confirmed 3 cyl has the number 4 and the unconfirmed tach has the number 3. The '95 has a number 3 below it, with and a mirrored 3
-again, under the speedo input, on the white casing is a barcode. confirmed 3 cyl has TN157320-7823 320 on it, unconfirmed tach is TN157320-7824 426, '95 4cyl is TN157350-9234 386
These could quite easily just be stocking numbers or something unrelated.
Can anyone provide any supporting or denying data for this?
PostPosted: Tue Apr 09, 2013 3:56 am
from a GT:
GT (4cyl) tach. Number 2 on it and mirrored upside down is a 4.
Two numbers on the bar code sticker. 157320-8051 and 34101-61E90
Made in Japan, so different plant, not a reliable comparison, but still good info.
