It is currently Fri Oct 20, 2017 8:39 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: New head is in
PostPosted: Sun May 12, 2013 12:39 am
@ssclown
Just got my head in from 3Tech im looking forward to starting my build.
 Post subject: Re: New head is in
PostPosted: Mon May 13, 2013 7:50 am
Looks good! What cam?
PostPosted: Mon May 13, 2013 8:52 pm
@ssclown
.375 / 226
PostPosted: Mon May 13, 2013 8:57 pm
Wonderful... looks amazing. Thanks for posting pictures. Can't wait to get one for my Mk1 and see the amazing gains that'll no doubt come about as a result of it.
1990 Ford Festiva Turbo - B6T Swap, 2.5" Exhaust, MX6 Intercooler, Hard Piping, K&N Filter, VJ11 Turbo
1987 Suzuki Forsa Turbo
PostPosted: Wed May 15, 2013 12:10 pm
yummybacon wrote:
.375 / 226
There's even a bigger one than the one I have? I think I want one, those cams are addictive :lol:
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Wed May 15, 2013 8:12 pm
@ssclown
A good buddy of mine is convinced that cam won't work im my car.He has said that i will blow head gaskets with this head and bored. 30 over.
PostPosted: Thu May 16, 2013 9:14 am
I think you have nothing to worry about. Mine isn't bored over, but the head is shaved a little. I hit 6k rpm everyday and drive at top speed a few times a week and the headgasket is still there 8)
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Thu May 16, 2013 5:17 pm
@ssclown
I contacted Mike asked him what his thoughts might be in a nut shell he said I took.040 off the head and you will be fine. I did order the good head gasket today (no blow) from ebay.now I'm off to the shop
PostPosted: Thu May 16, 2013 5:53 pm
you'll pick up a little heighth on the deck clearance with that head gasket.
i think that you'll like that engine. :wink:
PostPosted: Thu May 16, 2013 7:03 pm
I'm sure he will like it :D
Today I got reminded of how much I like it myself. I had to put the cat and the stock cam back in, or it wouldn't pass emissions. Sway bar and brace are gone too because of the cat, so for the next couple of days it's almost completely stock and I think it is pretty boring :P
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Thu May 16, 2013 7:11 pm
Hi! That info at your signature... what time did you do while still stock from 0 to 100 kph? Just out of curiosity.
image_id: 22616
1993 Swift Gti
PostPosted: Fri May 17, 2013 4:25 am
That would be around 16 seconds, cam makes a huge difference :D
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Fri May 17, 2013 4:20 pm
@ssclown
I'm considering doing something with the throttle body but I'm not sure what.Is there a different injector I can install?
PostPosted: Fri May 17, 2013 5:38 pm
The injector is not the problem. Contact maxbore.com and see what he can do for you.
PostPosted: Fri May 17, 2013 9:19 pm
@ssclown
Will do thanks Mike
PostPosted: Fri May 17, 2013 9:31 pm
@ssclown
http://maxbore.com/index.html
PostPosted: Fri May 17, 2013 9:47 pm
I used to do them, but just don't have the time anymore, so I spoke the owner of Maxbore and he said he'd be happy to take the G10 work.
PostPosted: Fri May 17, 2013 10:06 pm
what size do you think the overbore would be for a G10
how about G1.3B
***I'm a Suzukiholic,***
***Don't trust anybody that doesn't owne a gun or a chainsaw
ramblerkid wrote:
PLEASE DO NOT USE THE FORUM TO CONTACT ME. THANKS KEN
PostPosted: Sat May 18, 2013 3:41 pm
@ssclown
how about G1.3B
if you go to the website they explain what they will do and will tell you how aggressive they are with the bore.
PostPosted: Mon May 20, 2013 7:23 pm
@ssclown
Thanks I'm looking forward to running the engine.I have one Dilemma I have a line on a GT for 200.00 it needs some love $$.I can't pass it up but the wife said the vert has to go.Sad day in the Great Northwest.
PostPosted: Mon May 20, 2013 8:45 pm
Your wife is giving you an ultimatum over $200?
I say the wife has to go :P
PostPosted: Mon May 20, 2013 10:09 pm
@ssclown
No not on the money its a matter of room.I have a few Vehicles 06 blazer,vert,78 cutless,06 kia,91Geo and maybe the gt.Its getting a little cramped at the homestead.Now i say all of that but i might be able to change her mind not sure how but i have m :wink: y ways
PostPosted: Thu May 30, 2013 9:28 pm
@ssclown
Up Date
The machine shop is taking there sweet time they are a week behind.They said the block is done and they will are moving on to the crank.
As soon as they are done I will take some pictures and post them.
PostPosted: Thu May 30, 2013 11:09 pm
Mr. Bacon
If your not keen on my owning the vert again (would love to have add it to the pile)
I have a guy would you like his number.?
(he want a driver) and is a nonwrench
Maybe that will give me some Karma points towards said Bro'ham
the mark 8 went to the weeds yard art (very sad) some people you just can't help
......s
PostPosted: Fri May 31, 2013 12:20 am
@ssclown
Mr. Bacon
......s
That maybe good i will think about it.you know its summer time people want verts even if they are geo's
