It is currently Sun Feb 18, 2018 6:16 am
PostPosted: Sun May 12, 2013 4:57 am
Hi Folks,
My first post on here I think, normally over on the MightyBoy forum ;)
Picked up a '91 G10 alloytop 5sp Swift as a commuter and been sorting out a few small issues as I go. Had the intake manifold out to get the coolant spouts replaced, and in refitting it have broken a part.
From reading all different topics on here ( http://www.teamswift.net/viewtopic.php?f=5&t=49570&hilit=+vacuum+valve and http://www.teamswift.net/viewtopic.php?f=5&t=39692&hilit=+vacuum+valve for example) I have seen it referred to as a Thermal Vacuum Switch Valve, a BiMetal Vacuum Valve, etc..
Basically it's the Thermally activated (wax pellet inside) 4 port switching valve that is fitted to the back of the intake manifold.
What I am chasing is a part number or online listing of the part, as well as a diagram or even just an explaination of which vacuum connections go onto it (to make sure it's hooked up right)
Can you guys help out?
File comment: Even a picture - excuse the muck from excess Bar's leak the previous owner filled it with.
PostPosted: Sat May 18, 2013 8:22 am
Well, found it out, not a cheap part though
Suzuki Genuine 18124-60B10 AU$115
Also replaced the clogged PCV as well, and the engine runs a lot smoother now.
