It is currently Sun Oct 22, 2017 11:35 am
PostPosted: Tue Jun 11, 2013 1:27 pm
For years my stock G10 has had a spot just above idle that is non-linear; results in jerky acceleration when driving slowly. I have fiddled with various things (it has been a while) without luck. I don't think anything is broken, car runs great. Any ideas?
PostPosted: Tue Jun 11, 2013 1:36 pm
Did you check the TPS? An analog meter will be better, as it's more "graphic"; when looking for flat-spots (inconsistencies) in the resistance-readings.
A vacuum leak or fuel problem could also cause a jerky acceleration.
image_id: 22616
1993 Swift Gti
PostPosted: Mon Aug 19, 2013 4:48 pm
When I bought my cultus I had a flat spot under initial acceleration and upward gear changes. Turned out the two hoses on the vacuum advance unit were mixed up. Or as said above, you may have a vacuum leak. There's a good fww vacuum lines on and around your carburetor and they will wear over the years.
PostPosted: Mon Aug 26, 2013 5:58 pm
I just had the same problem and changed the tps and it's running great now.
Ken........
Users browsing this forum: No registered users and 9 guests
