It is currently Thu Oct 19, 2017 6:09 am
 Post subject: overheating geo metro
PostPosted: Sun Sep 08, 2013 4:02 pm
I have a 93 1.0 liter geo metro. I have ben loseing water for a while.I can fill it up drive ten miles and then it starts to overheat.I have replaced the radiator took thermostat out.The coolant fan comes on like it is supposed to.I presssured up each cylinder with 120 lbs psi and looked for bubbles in radiator no bubbles.I pressured radiator to 15 lbs and it held pressure and no water in cylinders.I pulled water pump and looked good no loose impellor or anything.I put one those gas combution in radiator color of solution stayed blue.I have a new pressure cap.It has 160 psi compression just loses water and then it overheats.I got a problem and get drive car very far.IT runs good no white smoke anytime and no leaks.Ii just blows coolant out of overflow and then overheats :buzz: help philrmech
