It is currently Tue Jan 16, 2018 6:31 am
PostPosted: Sun Jan 26, 2014 2:55 pm
I'm sure this has been covered plenty of times, but it's not came up on my 'search'.
When I took my engine apart, I should have learned to take better pictures. Blurry pics don't help for nuttin. In case anyone gets curious in the future, the mid-93 Metro Cam Gear has a 60A and an 80A mark with notches for timing. Unless I've really got it messed up. If so, Moderator just delete this.
From what I've read, the 80A has something to do with the DOHC 13B.
For the SOHC 1.0 3 cylinder, when putting it back together, the 60A is what I think is used.
All the experts that say "line up the Cam 'V' notch thingy with the other 'V' notch thingy, in conjunction with the 'V' notch thingy of the crank...blah blah blah...", but I've not found any to say "60A" 'v' notch thingy.....
IMHO, it's not a YES-NO, but an EITHER-OR.
PostPosted: Sun Jan 26, 2014 3:06 pm
viewtopic.php?t=18499&highlight=60a+80c
viewtopic.php?t=17645&highlight=60a+80c
The search must be broken again. I used Google.
Use 60A and the notch which is 180 degrees from it on the outside of the sprocket to align with the valve cover notch.
