It is currently Fri Oct 20, 2017 8:26 pm
PostPosted: Sun May 25, 2014 3:47 am
Hey guys need help.
The check engine light is constantly on, not flashing just constantly on. Checked the codes with a fuse in the port and it's reads the tps but it's an old code and so as you can tell I'm confused. Suggestions??
PostPosted: Sun May 25, 2014 5:06 am
Senior Member
scottlee wrote:
Hey guys need help.
Define old code. You are saying it is a code that has appeared before?
My understanding is that you can reset the ECU by:
1 Disconnecting the positive terminal of the battery
2 Turning the key to the on position
3 Putting your foot on the brake
The reason for steps 2 and 3 are to drain any residual stored voltage from the system. Once this is done, the ECU should drop any stored codes. If I have been given duff info, anybody.... feel free to correct this.
